Question about RCA RTD258 System
RTD258RV In RV not working - Power Loss
We too have this same unit and just one day it stopped working. Did you ever get a solution and can you share?
Stopped working... Power suggestions?
I have a feeling that it's on the same circuit breaker.
I would suggest changing the breaker.
May 13, 2014 | Dometic RM2652 Refrigerator
I have a Dometic RM2652RBX Refer. The last two trips out it has given us problems. The first trip it worked fine all the way to Texas. We spent 2 weeks in Texas with no problems. We went to the Grand...
If the RV was level when it did not function. First you will want to open the rear vent of the fridge on the RV and check for a yellow residue above the burner area. If you do see that, then you will require a replacement cooling unit because the pipe ruptured. It is common in all new RV fridges that the cooling units lets go within 3 to 7 years. Check out ArctiCold Refrigeration We keep it cold the replacement cooling unit can be purchased through Ebay Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 17, 2013 | Dometic RM2652 Refrigerator
I have a dometic refridgerator Rm3762 or Rm3962 one year old in my rv. It stopped cooling and is plugged in to 110. I was having problems on lp and restarted it a couple of times.
If your unit is working ongas,check your electric heater element locaged in the large round tube onthe righ handside when looking from the outside. You can check current draw , should be about 2.5 to 2.75 a/c amps. If electriccheck okand the gas is working, check for ayellow residue around the base of the refrigerator on the outside. Also if you have an amonia odor, this will indicate your cooling unit has leaked out and will have to be replaced. It could also be blocked which would cause loss of cooling. Hope this helps
Oct 09, 2011 | Dometic Rooftop RV Air Conditioner
I have a 2005 Pilgram 27 foot 5th wheel. My Duo Therm AC unit makes a ticking sound from the ac unit itself when it's not running. Shutting off the Duo Therm analog thermostat does not stop the ticking...
It's obviously on the 12voltDC circuit of the AC unit. Sounds like thermostat, or a relay in control box is faulty or bad connection. If you remove cover on ceiling assy., you should be able to hear it in the control box. There should be a model number on the ceiling assy., get back to me with that number and I can better pinpoint which relay. Also, try moving all thermostat buttons and temperature controls back and forth quickly to see if it may clean off a dirty circuit in thermostat as well. Make sure your AC hydro breaker is off when working with ceiling assy. just to be safe.
Mar 26, 2010 | Dometic Rooftop RV Air Conditioner
RV AC unit won't cool, blows chuncks of ice
It's most likely an airflow problem, you say you had the vents closed? Icing up is normally caused by lack of load (air flow) or loss of refrigerant charge. Make sure all your vents are open to allow for as much airflow as possible and that your filter is clean. Some units do not work well on low airflow setting when the outdoor temps cool down at night.
Sep 09, 2009 | Dometic Rooftop RV Air Conditioner
Lexicon RV-8 wakupe failure
Did you try this....
In the event of a power outage, the RV-8 will display a BROWN
OUT!! PRESS STANDBY message. To turn the unit on, use the
STANDBY button. For more information, see “POWER
MANAGEMENT” on page 3-3....
POWER MANAGEMENT ON, OFF
"Setup" >> "Power Management"
Opens the POWER MANAGEMENT menu, which is used to automatically
put the RV-8 into standby mode during brownouts.
When set to ON, the RV-8 detects low voltage levels or a momentary
loss of power and puts the device in standby mode. In the event of a
power brown out, the RV-8 will display a BROWN OUT!! PRESS
STANDBY message. To turn the unit back on, use the front panel
STANDYBY button.
When set to OFF, the RV-8 will attempt to function during a
momentary power loss, however software settings may become
corrupt and need to be reset.
When the RV-8 is in standby mode, pressing the button turns the
unit on and activates all zones that were active in the previous
operating session.
The RV-8 does not power on.
1. Make sure the rear-panel power switch is set to the | (“on”)
position.
2. Attempt to power on the RV-8 with the front-panel Standby
button and remote control On button.
3. Examine the power cord to ensure a good connection between
the rear-panel AC input connector and the wall outlet.
4. Check the electrical circuit and breaker.
Apr 05, 2009 | Lexicon RV-8 V2.0 Amplifier
Power to the roof but not working
In my own oppinion I would if it is available, as you do not know if something shorted out..also note that you may have too as updates are constantly done in the RV bussiness..I worked at 2 RV dealerships and there were constant updates especialy Dometic refrigerator and cooling units. Stop at the local Rv shop and see what they have or they may order it for you.
Apr 04, 2009 | Dometic Rooftop RV Air Conditioner
Microwave inoperative on rv generator power
Replaced with different microwave. Amanna microwave works fine on both circuits. Would not recommend Whirlpool for RV use.
Thanks
Dec 27, 2008 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Oct 24, 2008 | Dometic Rooftop RV Air Conditioner
RCA RTD258 System Logo
48 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
