Question about Hitachi 51F59 51" HDTV Projection Television
Sound But No Picture
I have the same problem but if you see a white line then just give it a tap in the back of the tv.
  • 4,234 Answers
The problem as you describe it usually means a vertical problem for a standard TV and the solution is either to resolder the pins of the IC or to replace it. I am not familiar with the board layout of your model, but there should be a small flat IC attached to a heat sinh with about 9-11 pins. It may be marked LA7837 or something similar. Try resoldering the pins first. If that fails to resolve the problem, replace the IC.
Please note that there are potentially dangerous high voltages present even with the set unplugged.
Dan
Posted on Jul 17, 2009
Testimonial: "I just ended up buying another one. It costed less than it was to fix the old thing. Thanks though."
How do I hook up my dvd/vcr to the tv
On the back of the cinavision you have two groups of sockets. The yellow socket under Video out is picture. Red and white is sound. Connect them to the TV's yellow red white sockets marked Video In 1. This connection will give you picture and sound from either the VCR or the DVD deck.
There's a better picture quality available for DVDs only from the Component video out sockets (green red blue). Next to them is another set of audio sockets (red white). Connect all five sockets to the TV's input number 2. The colours match up. The picture from Component will be clearer and sharper.
On your Sharp TV remote, select Video 1 to watch VCR, and Video 2 to watch DVDs.
Nov 07, 2014 | Sanyo DP39842B 39" 1080p LCD TV...
White fuzzy thin vertical lines appear on screen. The picture is fine, but the lines are in front of it. Is this something than can be repaired?
Hello can you post a picture of your tv set with the fuzzy white lines thank you so I can give you the best sound advice.
Aug 19, 2014 | Sylvania Televison & Video
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
Feb 08, 2013 | Hitachi 46F500 46" Rear Projection...
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
Picture probs with Orion 14"CRT TV
there is a poor or many poor solder joints in the vertical section of you tv, this is a simple repair for a technician. the set should not be used until this is fixed or this could damage other parts of the television.
Oct 07, 2009 | Televison & Video
Black Screen with a white line through the middle of screen.
The Flyback i'e the circuit board on the back of the tube as thus malfuctioned and give you this white line with sound.. If you did not have sound we would be discussing the PSU "power supply unit" This fly back for a 27 inch will run $105 plus tax.. The installation thereof would be done by a technition witch will charge 15 to 20 per hour.. Okay here is the sad part you can recycle this TV and get a flat panel for much cheaper then it would take to repair this unit "i am just telling you the truth" But do not shoot the messangero n this one, since I did tell you you're proble could you leave a rating?
May 24, 2009 | Insignia NS-27 TV TV
Tv beginning to flash green with horizontal white lines
From your description it sounds like a bad picture tube. The lines are called retrace lines. There is a small chance that a component on the small board that connects to the neck of the tube may be bad. Without model number information it is very difficult so say further. Some picture tubes can be re-jeuvenated with the appropriate machine ( at a TV repar shop)
If you feel adventurous and are careful you might try GENTLY tapping the neck of the tube and see if picture improves/goes out. If the tapping does change the picture it is definitely the tube
Mar 12, 2009 | Loewe ARC332 32" TV
Toshiba CF36G40 36" TV Problem
IO board has bad solder joints or is bad if you tap the outside firmly it will come on for a while
May 28, 2008 | Toshiba CF36G40 36" TV
Tosjiba cn32g90 no picture or sound
Timm,What you have Is Vert Failure,Toshiba is Noted for Bad Conns On the Vert Ic,Pull the Back off and Gently tap with a NonConductive Inturment and watch the Sceen Look for Heatsinks and Tap on those,If you know,or you caqn solder do so ,Do run the tv for a long time with no Vert or it will Cause BURN IN in the Phophurus
Jul 15, 2007 | Toshiba CN32G90 TV
Sound but no picture
A white like across the screen means that the vertical circuit has stopped working. Look for a small fuse that looks like a resistor near the vertical output IC, replace that fuse if open and resolder the pins on the vertical output IC.
Jul 08, 2007 | Toshiba CZ32V51 32" TV
Hitachi 51F59 51" HDTV Projection Television Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
