Question about Samsung Digimax 4010 Digital Camera
Wont power up
I saw that anouthe guy had the same problem but did not see a fix. is there any and if so what is it? thanks kevin
  • bonehaid Dec 15, 2007
    I've changed the batteries.
My 4010 samsung cramera will not power up with the card in it.
If I take the card out it will , the card works in other cramera so what is the problem.
Posted on Dec 25, 2007
Wet plug wont start and really smokey when it dose start
perhaps you are using too much oil , and if so the exhaust might be plugged . had similar problem with a roto tiller . burnt out spark guard muffler and walla it was fixed .Old guy was using 4 times the oil required .
Aug 31, 2015 | Husqvarna Partner K 750 OilGuard Saw
I press power on an accident and i try to fix it but it wont work
Did you try pressing the 'Power' button again?
Jan 04, 2011 | Televison & Video
Remington 16 inch chainsaw model 107624.01 . A friend burned out the motor can this be fixed. The saw was like new. Thanks Lou
anything can be fixed,but if your friend burned the motor,and if he is a up and up guy he should replace it.they do not cost that much
Sep 12, 2010 | Remington 16" Electric Chain Saw Assembled...
Bevel only goes to 43.5 degrees instead of 45. No idea why. I went back to Lowes and the display model does the same thing. Any fixes?
Sounds like the factory didn't calibrate it properly, there should be an 8mm bolt that you can adjust to bring the stop to 45degrees.
Feb 03, 2010 | Hitachi C10FCH2 10 Inch Miter Saw With...
White wire pulled out of the switch box. how do we reconnect?
If you cant access the switch box internally to reattach, then you'll need to purchase another saw. It will cost more to have an electrical shop or small engine shop fix it, then it would be to buy a new one, that is, if you cannot do it yourself.
Hope that helps.
Sep 12, 2009 | Poulan 952801953 Electric Chain Saw
Key wont start security light problem
if the security light is on leave the key in the ignition in the run position for ten minutes untill the light gose off or starts flashing make sure its the factory key or else it wont work
Jul 17, 2009 | 1999 Chevrolet S-10 Pickup
My husbands wet tile saw needs bearing and we were wondering if it would be worth it to replace the bearing or just buy anouther one?
surley nothing wrong with fixing old one.If bearing is a easy one to get.Another thing to consider how much does he use it if for his every day work new would give less prob and warrenty.lookup make online should find part from the maker.hope helps
Apr 14, 2009 | Saws
Chan saw tension
Hi Kevin
The engine is rotating clockwise and the chain saw as well(look at the chain "s theeth.
cheers savumihai71
Dec 06, 2008 | Garden
Mitsubishi projection Model # VS-50501A (Power cutout)
they are fairly similar to each other, did you get a error code from the led by pressing menu and input both in together and holding for 5 seconds?
Aug 19, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Ler states on the xbox360 is red
Hi m8 the only salution i know of is to send the console to these guys. if the problem is 3 red lights they should be able to fix it
Aug 24, 2007 | Microsoft Xbox 360 Console
Samsung Digimax 4010 Digital Camera Logo
Top Samsung Cameras Experts
Are you a Samsung Camera Expert? Answer questions, earn points and help others
