Even though there is no water connected, you will probably have to turn the ice maker unit to OFF so it stops trying to harvest... If you are never going to use it, simply remove it by taking out the one 1/4" nut screw on the bottom and the two screws above the unit, then unclip the wire harness. It will give you more room and cease the endless clicking... Amana Ice Maker Assembly D7824706Q
SOURCE: Humming in Whirlpool Side by Side Refrigerator
It is probably just your water inlet solenoid being activated. Not to be concerned.
SOURCE: clciking noise
I was having the same problem.
I read on fixya that there is a reliability issue with many models.
I called GE customer service. They sent a repair guy who swapped out the motherboard at no charge even though it was out of warranty.
Works great now.
2 of my neighbors' friges went out in the summer here in Las Vegas. They both lost all their food.
He said I was lucky because after the clicking noise begins, the motherboard usually crashes the next day. Mine clicked for a month.
SOURCE: Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
SOURCE: All display panel lights are blinking,
Bad main control sits on the back of the refrigerator about half way up on the left metal cover. Part number 12920710 double check against model before buying runs $170.
