Question about SanDisk Sansa e260 MP3 Player
Image Load Error,can't switch to MSC mode to use firmware updater
My sansa e260 gives me a message telling me that there is an image load error and that I need to enter recovery mode. I found that you are supposed to be able to get a firmware update that will fix the problem, but you need be in the MSC mode for that to work, and mine ins om the MTP mode. I can't switch it to fix it.
I fixed it by finding someone else who had the same problem. I downloaded a firmware file that they posted and put it on my mp3 player with a blank text document. I don't remember what I had to label it, or where I got the file though.
Posted on Jul 21, 2009
When i power it up it is reading at the top of the screen load main image failed switch to recovery mode then it just freezes
Download the software after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......recovery mode lock the sansa hold center button in and push and hold the start/menu button until recovery mode....Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Dec 21, 2010 | SanDisk Sansa e260 MP3 Player
My e260 is saying "load main image failed switch to recovery mode" what that means
Load main image failed, this is a firmware error, (this does not have software like a computer)
Recovery mode, the player tried to recover from the error.
The player has firmware updates that where put out by the MFG because of problems.
You have to read the manual, carefully and follow it to the T.
because you need to update the firmware on the player.
This is there website.
http://kb.sandisk.com/app/home
Feb 08, 2010 | SanDisk Sansa e200 MP3 Player
Sansa 260 R load main image failed message
The Sansa e260 Rhapsody could be recovered by resetting the player.
How to reset the player :
1. Player switched on.
2. Press and hold the power button for approximately 30 seconds.
3. Put the player back on.
When the fault is not resolved a firmware update / reinstallation needs to be made. There are 2 steps needed for getting new firmware on the player.
Step 1: switching the player into recovery mode / MSC mode
1. Turn off the player.
2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
3. Press and hold the REC button and connect the device to the computer.
4. A message will appear on the device display screen confirming the connection and a memory partition will be viewable in My Computer.
5. Release the REC button.
Step 2: Update the firmware ( updating firmware always in MSC mode, see Step 1 )
Use next link for updating the firmware:
http://kb.sandisk.com/app/answers/detail/a_id/306
The Sansa updater installation on the computer should be the easiest way to update firmware.
Need more help ? Just post a comment.
Dec 17, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
Kashif
I had the same issue I think to switch to recovery mode you lock the keys and hold the record button as you turn on the player. The only place I know of the get the firmware is the official website.
Jul 13, 2008 | SanDisk Sansa e260 MP3 Player
Load main image filed switch to recovery mode
you need to update the firmware on it..i had the same problem but then it started working again once i added the firmware to it
Apr 16, 2008 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
202 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
