Try here!
http://www.ereplacementparts.com/ryobi-trimmer-parts-c-7931_15633.html
Good Luck!
SOURCE: Strimmer Line
rotate the starter pulley by hand. You should feel the spring getting tight. Once the pulley is slightly tensioned, usually 5-10 turns, release the pulley and let is pull the string onto the pulley. You may have to add some tension to get all the rope to wind on the pulley.
SOURCE: Manual - Ryobi RLT30CES strimmer
Try this one:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Cheers
Nigel
Testimonial: "Thanks. Got it."
SOURCE: Ryobi PBC 3046YE strimmer starts but cuts out when speed control
A lack of acceleration in these units is most likely a fuel delivery related issue. It may possibly be time for a diaghram kit or carb rebuild kit to be installed in your carburetor. Ethanol in the gas deteriorates the parts that accomplish the acceleration procedure and may need to be replaced as they don't function anymore.
Many other things can affect these little machines as well such as clogged air filters, clogged crank case vent, clogged mufflers/exhaust ports./ spark arrestor screens...but more often than not, your problem is a carburetor issue.
Please look at the troubleshooting section on this Zama site PDF file
http://zamacarb.com/pdfs/TechGuide_2007.pdf
It's a ryobi strimmer re-badged- check ebay...
