Question about Nutrifaster Ruby 2000 Juicer
Need replacement part, the cutter blade - Nutrifaster Ruby 2000 Juicer
    Problem Solver:
  • 14 Answers
Call 02-97292011 for parts
Posted on Aug 01, 2013
Problems dismantling champion juicer
It's like a suction is created. I have had this happen. I managed to get mine off with a blunt knife to give a bit of leverage (not ideal I know to put a knife near an expensive piece of equipment but it worked for me) Once you have the blade cutter off I suggest oiling the metal prong that it sits on with something like vegetable oil or olive fairly regularly to avoid this happening again.
Feb 23, 2014 | Champion Juicers
I need a cutter blade parts no 015180. Can I pay for it on the net?
You can buy it from Waring or Omega, same blade.
Or, just google Acme juicer parts. $20 to $30. Look
out though, found new blade increases vibration. You
can also sharpen old blade by slightly drilling into
each burr on the blade with a small drill bit. Been
using the same blade for several years.
Jan 28, 2011 | Acme 6001 Juice Extractor
I cannot remove the blades from the shaft. This juicer has been in storage with all the attachments in place. I was able to pry it out about an inch or so but can't get it any further. Is it safe to use...
Do not use WD40. Wear heavy leather work gloves. Lightly tap two flathead screwdrivers positioned opposite each other to initially pry the blade apart from the main body of the juicer. Alternate tapping on the screwdrivers until some of the shaft is exposed. Tilt the juicer towards the blade and drizzle olive oil on to the exposed shaft. Every few hours return juicer to stable upright position and use a hammer to lightly tap a screwdriver positioned at an angle that will not gouge the shaft. Rotate blade manually and tap in different positions. Keep juicer tilted towards blade in between tapping attempts to allow oil to penetrate shaft opening. Continue drizzling olive oil on shaft as it is exposed. Cutter may need replacement after this procedure. Use steel wool to thoroughly clean shaft. Soak Cutter blade in hot soapy water for two days.
Sep 30, 2010 | Champion G5NG853S Household Juice...
Acme juicer vibrating so much.
I've had one for 21 years and when I replaced the blade the same thing happened.
The blade is not supposed to be held firmly in place so it can slip intentionally to
minimize vibration. If you bought the juicer new, think back, and I believe you will
remember the vibration problem. I seems with a worn blade they vibrate less. The
motor is very durable and uses roller bearings like on a skate board. I went back
to the old blade, which I sharpen with a drill using a small bit.
Jan 11, 2010 | Acme 6001 Juice Extractor
Parts, the blade
BLADE IS AVAILABLE ON LINE. BELIEVE
YOU CAN USE EITHER ACME ($30) OR
OMEGA ($20)
Dec 24, 2008 | Acme 5001 Supreme Juicerator Juice...
Juicer heating and pulp is wrapping around blades
Parts from Champion website. You may need a new cutter, sometimes cheaper on ebay.
Jun 22, 2008 | Champion 2000+ Household Juice Extractor
Where can we locate a parts store?
The cutting blade can be found at http://www.waringproducts.com/ret/.  Waring now makes the juicers.  Good luck!
Mar 11, 2008 | Juicers
Nutrifaster Ruby 2000 Juicer Logo
2,004 people viewed this question
Top Nutrifaster Juicers Experts
Tom Chichester
David Payne
David Payne
Are you a Nutrifaster Juicer Expert? Answer questions, earn points and help others
