Question about Haier HPAC9M Air Conditioner
Haier 9000 btu; not able to set temp
Can not set the temperature.
  • 30 Answers
Setting temps on a Wall unit or a window unit - depends on where the Unit is in the room ( area), the stat in the unit is reacting to the the return air ( at the Unit) . If the Unit is not large /small enough then you will have a problem - 1. To Cold near the Unit and to warm the further away you are from it.
2. If the Unit is facing a wall to close, the unit can short cycle ( entire room will be warm). Dedending on the room and heat load - check and see if the Unit is the proper size. " to much of a good thing " is bad - not enough maybe to ( not cooling the area properly). #3 Control is defected ( age of Unit ? )
was not given.
Posted on Jul 18, 2009
Digital temperature changes to 86 every time your set it to a lower temperature how do I fix this
If this set temp changes on its own then the circuit board has failed. Call a service tech or replace the unit. But this 86° might be the indoor temp, not the set temp? If I set my temp to 75°, then my temp goes to 86°, then the set temp (target temp) is 75° & actual room temp is 86°. The unit may not be working properly. Not sure if this helps.
Jun 13, 2015 | Haier Heating & Cooling
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
LOST REMOTE BUT TRYING TO GET IT COOL...PLEASE HELP!!!!!!!...its a Haier 9000 btu model #HPRB09XC7
Stephanie, the Control Panel Operation is the same as the remote control. But, if the Control Panel is not allowing you to change the settings, turn the Master ON/OFF Switch to OFF and unplug the unit for 15 - 20 minutes. Then plug the unit back in, turn the Master ON/OFF Switch to ON and set the controls as you would like. Hopefully, the unit's electronics reset themselves during the 15 - 20 minute timeout and you will be able to operate the unit using the control panel.
Hope this helped you solve the problem.
Jun 28, 2011 | Haier CPRB09XC7 Portable Air Conditioner
I have a Haier ESA406K 10,000 BTU's that just
sounds like you have a small refrigerant leak which would at first result in the evaporator coil freezing over, then eventually not working at all.
Jun 11, 2011 | Haier Heating & Cooling
Need a owners manuel for haier air conditioner 9000 btu
To help you with the correct Owners Manual, I will need the correct Model Number for your Haier AC Unit. They make 3 different models for 9000 BTU.
Please advise. Thanks.
Jun 08, 2011 | Haier Heating & Cooling
9000 BTU/Hr split type system, heat pump ACU, 230 Volts
It is 3/4 TR. Consumes 4.6 amps maximum and can cover of 80 sqft area with normal height of 8 feet.
Heat and cool model. Keep heat mode and +5 degree more in temp setting for heat and keep -5 degree temp setting and mode in cool. All the best.
Dec 26, 2010 | Heating & Cooling
I have a Haier 5,200 btu air conditioner that
E-1. Indoor room temp sensor defective. replace it.
Jul 23, 2010 | Haier Energy Star ESA3183 Air Conditioner
Outside unit
Most probably you need refrigerant re-charging. This is one of its markers.
I hope it helps.
Jun 14, 2009 | Haier HSU09XCA 9000 BTU 10 SEER Rating...
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Haier HPAC9M Air Conditioner Logo
217 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
