Question about Sharp Office Equipment & Supplies
I am trying to find bulk toner for a sharp ar-bc320 I have been only able to find universal toner for other ar sharp models are they compatable?
    Scholar:
  • Sharp Expert
  • 120 Answers
The AR-C26TxU toner cartridges are only made for the AR-C260, AR-BC260, and AR-BC320. The cartridges are unique for these models in that they are the only ones in Sharp's entire color cartridge line that contain both toner and developer. I'm afraid you're going to be stuck with OEM in this instance, sorry.
Posted on Jul 20, 2009
Can't find sharp ar-bc320 driver for 64bit, there's only PCL5 driver which won't work, we need PCL6 driver for this model.
Sharp does not natively support or provide a PCL6 driver for this device. That being said, another possible workaround to provide you with a PCL6 driver for this is to try the HP Universal Print Driver for Windows PCL6 x64bit. This driver simply prints direct to the IP address that the printer uses on the network. You may sacrifice a few special features of the device using this driver, but I've had excellent success with it and recommend trying it.
Here's a link to the driver:
http://hp.driversdown.com/hp-drivers-download/HP-Universal-Print-Driver-for-Windows-PCL6-x64_18967.shtml
Hope this helps!
Jun 20, 2011 | Computers & Internet
I have an error code F2-41
Your copier is starved for cyan toner. The cartridge either ran out or its' countdown chip went to zero without your copier alerting you that it was running low, sometimes that happens on those models. Change your cartridge.
Sep 28, 2010 | Sharp AR-BC320 All-In-One Led Printer
Just replaced cartriges and there is a streak
The print software should have a clean option for the printer, try and run the clean 2 times and see if this does the trick.
Feb 04, 2010 | Sharp AR-BC320 All-In-One Led Printer
Printing from a mac OSX.5.8 to a Sharp copier AR BC320?
You will need to purchase the Post Script Driver for that model. Sharp Copiers require a product key code to enable post script on their copiers. A sharp dealership will have to sell it to you as well as to get the product key code for the postscript driver.
Dec 10, 2009 | Sharp AR-BC320 All-In-One Led Printer
Sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Apr 20, 2009 | Sharp Office Equipment & Supplies
I have a F2-41 code. What does this code mean?
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
Apr 15, 2009 | Sharp AR-BC320 All-In-One Led Printer
I can't change the printer IP Sharp AR-BC320
If you know the IP address, connect the printer with a laptop using a cross cable. Go to the printer web page by typing the IP address of the machine in the Internet explorer. Browse the menu under network setting and save after you change the gateway
Dec 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Copier Sharp AR BC320
i'd try consumer reports or Cnet.com for reviews, and that might let you know more about it..
got backup for that computer?
Feb 19, 2008 | Sharp AR-BC320 All-In-One Led Printer
103 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
