Question about HP Computers & Internet
My monitor will drop the colors
Most of the time the monitor color resolution is pretty bad red will show are gray blue will show as mauve. is this fixable??
  • 4 Answers
Check wheather is there any land phones are there, or any sound speakers present beside the moniotr.
than also not working give the monitor to repair.yes it is fixable.
Posted on Jul 18, 2009
Monitor flashes different colors
Monitor has been successfully broken with fall.
Aug 31, 2017 | Samsung P2370HD 23 in. TV
I painted light gray that now looks lavender on the wall...I am pretty sure it is the lighting in the room (CFL bulbs) as when I take the roller into another room with natural light or fluorescent lighting...
I painted for many years. And now work with photoshop each day.
The selected grey was probably in the blue family instead of yellow family. Most interior colors look better if they come from the warm yellow family, including greys.
There are greys for every color in the spectrum ... from yellow to red to blue. If you pick a grey with bit of red, it will start to look mauve. Orange and it will look brown. Blues inside the grey will turn purple real quick.
Moreover, all colors and finishes are contextual and pick up surrounding colors. Especially satin-or-shiny finishes, because they pick up local colors that change intended hue. For example blue drapes will turn white room bluish. If the house next door is red, and the light comes in window, it will turn white room into pink. Green leaves, and the light from window turn white room green. So when you pick a grey that has bit of blue, the color can change for many reasons beside light bulb. Each room is totally different.
Most folks pick colors by looking at color chip in the store, instead of painting a section of wall inside home. And most folks do not ask the paint store clerk which tints are in that particular color. Sometimes the black tint will turn some bases into a bluish hue.
Go back to paint store and get another grey color from the yellow spectrum.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 20, 2013 | Home
Unstable color output of monitor missing color blue and red what is the recommended software?
This sounds more like a hardware problem. If blue and red are dropping out, you likely have a poor connection. If the connectors are snug, the cable to the monitor may be bad.
May 22, 2010 | AlphaVision Alphacam PLUS Webcam
LG Flatron W2234S 22 purple tint problem
your LCD monitor has bad ccfl lamps or inverter circut..
May 08, 2010 | LG 22" FLATRON LCD Monitor
My monitor is not showing red colors? how do i fix
There is a number of possible reasons why your monitor lost the red color. A good guess, however, is a broken cable or connector. Check the plug and socket of the cable for bend or broken pins. If everything looks OK, try to change for a different cable.
If the problem persists, a pin of the connector soldered to the PCB internally may be broken. This is an easy repair for a service technician but I really recommend you do not do it yourself.
Feb 05, 2010 | Dell UltraSharp 1907FP 19" LCD Monitor
Color Problem
all of you mentioned are correct. if they cannot work on color setting of your monitor and for the setting of your resolutions it could be the monitor. the monitor cannot support the color bit mode which required for the windows vista it could be a 16bit color mode which only display for not more than 63herts for the Hi color vsynch compare for the 256color if you have a Hi color settings for about more than 63herst vsynch. it cannot display properly. thanks
May 10, 2009 | SVA-USA VR 17 17" Flat Panel LCD Monitor
Monitor problem
You didn't specify the card you are running but here is how I would approach the issue.
#1 refurburished Monitors have at a minimum a 90 day warranty, so be prepared to call Dell Tech Support and troubleshoot if my information doesn't help, if the monitor is defective, then they will have to exchange it.
#2 The optimal Resolution is 1680 x 1050 60 hz, you need to ensure that setting (You didn't specify, so I mentioned it)
#3 Sometimes color issues are caused by cabling issues. Try both DVI and VGA connections, see if there is any difference between them (digital or analog, the picture should look the same) If one looks ok, the other doesn't. then it may be a bad cable.
#4 Does the issue occur on more than one system. If it does, then the monitor is bad. If you have individual pixels stuck on (Red, Green or Blue) and you have more than 6, that in itself is justification for replacement.
#5 If all the above doesn't work, contact Dell Tech support for an EXG
Jun 08, 2008 | Dell E207WFP LCD Monitor
Picture is Gray, does not show any color
Are you using component cables (red/green/blue)? Check your connections to see that they are all seated properly. When using component cables, if only the green is plugged in, it will give you a black and white picture. You will get color once you plug in the red and blue.
What kind of sources are you using? what kind of cables are you using? Need these kinds of specifics to ehlp you out.
Mar 28, 2008 | Televison & Video
Computers & Internet Logo
44 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
