When you go through the set up you will see 12:00 flashing. Push the set button again and you will see 24:00 flashing, select this and move on and should be good
Gabe Barrow, Barrow's Jewelers
I have the Yoho Sport Fitness Tracker Smart Watch. There was no option to change time format on the Yoho Sport app. However, on the watch, long-pressing the power button while on the time screen changed the time format between 12 and 24 hours.
To set the hour format, press S1 button
to toggle between 12-hour and 24-hour
format. The P.M. indicator may be
displayed to indicate the time period
12:00 A.M. - 11:59 P.M. in 12-hour
format.
11.To set the calendar format, press S1
button to toggle between M-D (monthdate)
and D-M (date-month) format.
12.After finished making all the settings,
press S2 button to confirm...
There are several models of your watch not all of which appear to have a 12/24 hour display format.
Try this extract from a manual; press the MODE button six times to enter the 12/24 adjusting setting and then use the START/STOP or SPLIT/RESET button to change the time.
Press the mode button to return to normal operation.
To change between 12 & 24 hour display, press the mode button (bottom left) and then the bottom right button to change format. Press mode until normal display is achieved.
Press and hold the top left button for 2 seconds to go into the time adjustment mode.
While you are in this mode press the top right button to switch between 12 hour and 24 hour modes.
Press top left to return to normal.
NOTE: 12/24 HOUR TIME IS SELECTED BY PRESSINGRESET/LIGHT ONLY WHEN THE HOURS MARKER IS FLASHING. THE “A” OR “P” WILL DISAPPEAR WHEN THE WATCH IS SET TO 24-HOUR TIME.
