Question about GE JKP27 Electric Double Oven
I need an oven element for a GE JKP27...Can you help? Jim
    President:
  • GE Master
  • 1,922 Answers
"Appliance Parts Pro's" web site they'll have one and their prices are REASONABLE and shipping is FAST too
Posted on Jul 25, 2009
Installation instructions and manual
Most of the installation manuals for GE appliances are available on their support page: http://www.geappliances.com/ge/service-and-support/literature.htm . I found several double wall oven models with the JKP27 designation. However, the G0J4BG does not fit as part of the model number. There should be 4 letters after JKP27 in the model number. These letters primarily indicate the color of the exterior. For the JKP27 models, the installation manual says that the cut-out should be 32 1/2" above the floor. The depth has to be 23 1/2". The cutout width should be between 25" and 25 1/4" (these are an absolute minimum and maximum). The cutout height should be between 27 5/8" and 28 1/8".
The direct link to installation manual for one of these ovens is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675840.PDF . See page 6 for the cut-out dimensions.
I hope this helps.
Feb 05, 2018 | GE JKP27 Electric Double Oven
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
GENE
Sep 28, 2011 | GE JKP27 Electric Double Oven
GE model # jkp27 error code F1 what should I do?
Hi ssantillo,
Usually F1 error code means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope this helps.
Thank you for using FixYa.
Apr 27, 2011 | GE JKP27 Electric Double Oven
In the upper oven, the lower heating element started sparking when turned on, and now it looks like it has a 'bubbled' area (about inch long) on it and it looks bent on one area. I guess I need to...
Hi, Yes, that element is toast...
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 20, 2010 | GE JKP27 Electric Double Oven
My oven will not turn off. Can you tell me why
i think the oven that you have is electric and it does not have a ignitor. and that the oven thermo has shorted contacts and this is why the element will not turn off . it may also have run a way tempts . . so if the tempts are to high and cn't control tempt // replace the ocen control .. mm
Jul 14, 2010 | GE JKP27 Electric Double Oven
Replacement oven racks
The rack can be purchased from GE online or over the phone the part number is WB48X73 cost is $99.75
Feb 25, 2010 | GE JKP27 Electric Double Oven
We have a double wall oven which is 16 years old. The top oven doesn't heat above 150 and the bottom oven is overheating...the oven said 375 and an oven temperature gauge said 450. Is this fixable or do I...
I have the same issue. Only answer I found was the elements may be burned out. The bottom oven is separate (knobs).Go to GE site and see how to adjust the thermostat (behind a knob).
Nov 01, 2009 | GE JKP27 Electric Double Oven
Top oven will not heat all the controls are active, bottom oven works fine.
check voltage to element. should be 240v. if voltage is good then replace element.
Jun 21, 2009 | GE JKP27 Electric Double Oven
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
Ovens Logo
211 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
