Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
I cannot find the booklet on the rheem's hot water heater to adjust the water temp. Model # 42VP50Fu. Thanks We just moved into this home and would like to lower the temperature. Bill and Arlene
  • 297 Answers
Hi,Bill and Arlene,in front of the unit there is a square box,on that is a dial,turn it to the right for more and left for less. please rate my answer.
Posted on Jul 21, 2009
Rheem hot water heater says set temp? no hot water
If it is a gas water heater you must set the temp on the gas valve. Press the two outside buttons until they flash. Now you can use the arrow button to set temp.
Jun 25, 2016 | Rheem Water Heaters
Why do we need to have to continuously adjust the temperature of the water when we're taking a shower. We have a new Rheem gas .hot water tank
It *may* not be a problem with the water heater itself necessarily. When you say "keep adjusting the water temperature when you're taking a shower" I presume you're talking about turning the shower hot/cold knob(s) and not the temp thermostat on the water heater itself.
If so, when it starts to run colder, turn the knob all the way to full hot. Is the water then very hot? If so, the water heater is working fine & doing its job, and the problem is likely to be in the shower faucet mixing valve itself. Sometimes a faulty one will expand the inner seals/cartridge as hot water flows thru it, and starts to (wrongly) restrict the hot water flow, thus causing the constant need to "turn the dial up a notch".
Oct 29, 2014 | Rheem Water Heaters
Adjusting temperature
Turn off power -Remove tin cover plate and with a small screw driver turn dial right for more heat left for less .temp.,on the side of unit.
Jul 26, 2014 | Rheem Tankless Hot Water Heater...
Rheem water heater poor temperature regulation
Have a look at the water section might be getting clogged inside , slowing the flow .
Aug 01, 2017 | Rheem Water Heaters
Rheem rte13 standby (green) light not on
You might have crossover problem caused by bad faucet cartridge.
http://waterheatertimer.org/Crossover.html
The green standby light should come on when 240Volt power is applied. Page 6 manual.
Both red lights should come on when tankless is activated. Page 6 manual
RTE 13 requires 60 amp breaker and 6 gauge wire
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
http://waterheatertimer.org/pdf/Rheem-TanklessElectricUC_AP15447.pdf
Factory temperature setting is usually default 120 degrees.
Adjust temps page 11 manual
Thermostat calibration is always approximate.
120 degrees is not hot enough to burn the skin.
Exceptionally cold incoming water temperature can cause tankless not to heat enough hot water: install tempering tank to preheat water to room temperature.
Tankless cannot be exposed to more than 11 grains hardness in water. Delime tankless yearly, clean water filter monthly, do not install low-flow restrictions or conserve water since the flow rate must remain high for tankless to activate.
Rheem does not post service manuals for their tankless water heaters.
Call Rheem 800 432-8373
Aug 05, 2012 | Rheem Tankless Hot Water Heater...
Just moved in to our home. How do we know the water heater is full before we light the pilot light?
Is the water on? Run the hot water faucet until there is no more air escaping ... evey faucet in the house.
Thanks for your question.
Jun 19, 2011 | Rheem Water Heaters
Doesn't seem like we get enough hot water, how can i change the temp settings?
Remove cover plates from front of heater, usually four screws each.Seperate insulation enough to see and you will see the thermostat. It is factory pre set at 120 degrees and normally be adjusted to 140 degrees. Use a small blade screw driver to adjust settings. Ihope this helps you. Thanks
Nov 15, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem glas fury water heater rattling
Thermostat may be heating element hotter than normal causing a change in temperature causing the noise. You could try adjusting temp down a little on thermostat. It sounds like it's getting the water very hot and thermostat may not be working correctly.
May 21, 2010 | Rheem 81VP6S/430126 Water Heater
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
I have a Rheem 21VP40E Power Vent NatGas water heater. It was with the house when we bought it. The problem is that lately we are only getting one shower out of the unit. Even during that one shower the...
As long as the tank is not leaking. Go to Rheems website, and look up your model.
As with any large home appliance I would recommend a plumber or HVAC professional licensed by your state to perform the repairs.
I am pretty sure the part you need will be the gas valve contoller.
Please elt me know what you find.
Feb 10, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
127 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
