Question about Saeco Royal Professional Espresso Machine
Dredge drawer full and it is empty
  • 1,089 Answers
Hi
One thing you want to make sure you do is leave the machine on when you remove the drege drawer other wise the machine doesn't know that you emptied it. Remove the drip tray and pull the empty drawer out about half way and leave out for 15 seconds. Then push the drawer back in from the right front side with 1 finger. That way you make sure that you engage the switches in the machine. If you slam the drawer in you can pull it away from the switch and it will say drege drawer missing. If you put the drip tray back in, it can sometimes lift the drege drawer and disengage the switch. There is a notch in the right side of the drip tray that has a flashing on the back side of it. You can remove about an 1" of the right side of the flashing and it will stop the lifting of the drege drawer. Remember to leave the machine on when you empty the drege drawer other wise it doesn't know.
Posted on Jul 18, 2009
2 Suggested Answers
  • 1089 Answers
SOURCE: DREDGE DRAWAR FULL SIGNE COMES UP. EVEN AFTER
Hi When you empty the dredge drawer, the machine must be on and in use. Take the dredge drawer out and leave it out for 15 seconds. If the machine is off when you empty it doesn't know that.
Posted on Jun 15, 2009
After emptying the dredge drawer and replacing it, the unit still says "Dredgedrawer Missing"
The sensor that detects the presence of dredge drawer is not closing. Locate it and fix it or just jump the wiring to the sensor.
Aug 09, 2015 | Saeco Magic Comfort Plus Espresso Machine
The dredgedrawer notification will not turn off on my solis 5000 espresso machine
Grinds sometime get lodged behind the drawer. When you replace the dredge drawer it doesn't go all the way in. Clean out behind it really well (maybe air blower fro computer) and try it again.
Feb 17, 2014 | Solis Master 5000 Espresso Machine
'dregdrawer full' message but not disappearing when emptying it
HI Are you leaving the machine on when you empty the dredge drawer? There has to be power for the computer to see that the dredge drawer has been removed. Leave it out at least 15 seconds, so the computer thinks you emptied it. This should clear the message.
Jul 09, 2011 | Saeco Incanto Classic Espresso Machine
Gaggia Digital Syncrony dredge drawer error won't
Hi
Do you still have the tab on the left side of the dredge drawer? If you do, you can loosen the 2 screw just above the slot wherer you put the credit card. Push down on the plastic ramp in the slot as far as you can, then holding the ramp down tighten the 2 screws. If you don't have the tab you will need a new dredge drawer. Also on some machines the drip tray will lift the dredge drawer and it will give this message. There is a extra piece of plastic in the 90 deg. notch that can be trimed out to stop it from lifting the dredge drawer.
May 14, 2011 | Gaggia Syncrony Compact Digital Espresso...
Machine shows message 'dregdrawer full' even thought the dreg drawer is empty. cant get rid of this error message.
Hi
When you go to empty the dredge drawer you must leave the machine on. When you remove the dredge drawer it will say dredge drawer missing. Leave it out at least 15 seconds so the machine knows you are empting it. When you insert it again the machine will count about 24 cycles and tell you to empty it again. Its a counter.
May 12, 2011 | Gaggia Syncrony Compact Digital Espresso...
Hi, my machine says empty dregs and I don't know what it means by that. Any ideas?
Hi
Leave the machine on. You need to remove the drip tray. Then pull out the big box(dredge drawer) on the right. Empty the contents. Leave it out at least 15 seconds. Then set back in its hole but don't push it in all the way. About half way in, push it the rest of the way in with 1 finger, pushing on the right side of the dredge drawer, until it stops. That way you won't have the problem of knocking off the lever on the drawer switch. You should never get the "dredge drawer missing" by doing it this way.
Apr 17, 2011 | Saeco Magic Comfort Plus Espresso Machine
How does a Saeco Magic De Luxe Espress machine know the dregs drawer needs the be emptied and turns on the light? Does is just count the pucks that are put into the drawer or is there some type of sensor?
Simple answer is it counts how many coffees have been made. If you turn the machine off and then empty the dredge drawer the machine doesn't know this. and the light will remain on. Leaving the machine on when you empty the drawer lets the machine know that you emptied it (15 seconds out) and it will turn the light off.
Oct 07, 2010 | Saeco Magic De Luxe Espresso Machine
DREDGE DRAWAR FULL SIGNE COMES UP. EVEN AFTER EMPTYING DREDGE DRAWER MACHINE WILL NOT RESET TO PRODUCT READY
Jun 15, 2009 | Saeco Royal Professional Espresso Machine
Faulty dredge drawer sensor
remove drawer and drain tray, there may be some coffee grounds on the back of the machine where the drain tray sits, preventing the dregs drawer from sitting properly.
Apr 10, 2009 | Gaggia Syncrony Espresso Machine
DregDrawer full message won't clear
When you need to empty the grounds draw remove the drip tray and pull out the dregs draw - don't open the side panel or turn off the machine, - It works for me!!
Feb 20, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
425 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
