Question about LG WM-2277HW Front Load Washer
My lg washing machine is leaking from the bottom please help me
  • 5 Answers
You may have already noticed there are several other owners with the same problem. After having lived with this problem for a couple of years, I finally filed a complaint with the Consumer Protection Agency and LG sent out a repairman. Thing is, they didn't know what to look for. When they took the door off the front of the unit they removed the drain pump and the hose attached to it. I inspected the hose and found a hole that had been worn into it from rubbing against the drum. It's a design flaw. The hose is not very secure in the machine and over time it becomes loose and rests against the drum so eventually a hole is worn into it. Once they replaced the hose and taped it to the side, the problem was solved. But I suspect it's only a matter of time before the hose shakes loose of the tape and dangles against the drum again, and getting another worn into it. If I can get enough consumers to help, I would like to file a class action lawsuit because this a very dangerous situation that LG has not offered a solution to.
Posted on Jul 19, 2009
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
  • 311 Answers
SOURCE: washing machine is leaking from bottom
Take front off and see where leak is coming from. Most common is either a split hose or bad tub seal. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
futureloginn
  • 734 Answers
SOURCE: water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
futureloginn
  • 734 Answers
SOURCE: My Ge washing machine is leaking from the Bottom
During fill only
All the time
During fill only
All the time
  • 4 Answers
SOURCE: Leak coming from the bottom of my washing machine
you probably have a tear in the bellow. cost to replace a few hundred dollars.
Posted on Jun 09, 2009
Lg front loader washing machine is leaking from front door at the bottom
clean glass at bottom of door. maybe tear in door boot.
Jan 14, 2017 | LG Washing Machines
I would like to know how do i stop the water from leaking at the bottom i have a LG WM2050CW 40 cu ft washer
wow more specific please. Sure its not leaking from the top and running down the sides inside the cover panels? If not hose leaking and or pump.
Dec 17, 2013 | LG WM2050CW 40 cu. ft. Washer
Lg intellowasher 7kg wd8074fhb
The water pump can be a source of a leak.
Oct 29, 2013 | Washing Machines
My LG WM227 HW is leaking water fromthe bottom of the machine while machine IS NOT in use!
You have a leaking water valve or drain hose. You will need to have a qualified technician to help you find the problem.
Good luck
Jun 10, 2011 | LG WM-2277HW Front Load Washer
I have a LG WM2277HW front loader washer . The door doesn't close all the way. It locks, but is kind of loose. I don't get any error messages, and it cycles fine(washes fine), but as soon as it starts...
If it is physically possible on your machine I would suggest that the door catch need adjusting, either that or it's broken but the door sensor still thinks it's OK ;-0)
Suggest a service call required ;-0)
Sorry,
John C
Mar 02, 2011 | LG WM-2277HW Front Load Washer
My LG 7kg frontloader intellowasher WD8013F is leaking from underneath and no water is going into the washing machine. Please help?
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
Jul 12, 2010 | LG Washing Machines
LG Washing machine leaks from the bottom when large items such as flannel sheets are placed in the machine. It does not leak at any other time but I had water all over the floor twice when I tried to wash...
Water may be working its way up and over the inner wash tub with the larger items. Ensure that you are not overloadinig the washer. You may want to contact an appliance service company.
Feb 22, 2010 | LG Washing Machines
Front bottom leak from my LG TROMM HE Washer
  • Hi
  • Try these:
  1. Inspect the water supply connections
  2. Inspect the drain hose
  3. Inspect the water pump
  4. Inspect outer tub for cracks or corrosion
  5. Inspect the tub seal
  6. Inspect the tub bearing
please rate my suggestion...
May 22, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Aug 14, 2006 | LG WD-16115FD Front Load Washer
LG WM-2277HW Front Load Washer Logo
943 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
