Question about Delta Faucet Delta 2457 Orleans Two Handle Kitchen Faucet with Side Spray, Chrome
I cannot get the set screw out of a Delta two-handle faucet. I may have stripped it trying to get it out. I sprayed it with Liquid Wrench, but I still can't get it out. What else can I do to get it out? I had no problem with the hot water handle, but this is the cold handle and the faucet is still leaking. Thank you
    Brigadier General:
  • 3,006 Answers
You can't apply any worthwhile heat to try and free this off without causing further damage, but if you have a pipe freezing kit handy you can try freezing it a few times and then pouring boiling water over it to thaw it suddenly. The thermal shock sometimes works but it's not a sure enough thing to be worth specially buying a freezing kit for.
That leaves two other possibilities: drill the screw out and get a replacement (or adapt one from another machine screw) or partially drill it and use a very small stud extractor. If the screw is brass then just drill it out in my experience as stud extractors just don't work on small diameter non ferrous materials.
If you drill the screw out then you need to use a drill bit small enough to go down the centre of the screw without damaging the threads, but large enough to leave it sufficiently thin-walled to be able to collapse inwards when you subsequently winkle it out. Usually I find that a pin punch driven anticlockwise against the thin rim left after drilling does the job.
Posted on Jul 22, 2009
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
Delta faucets troubleshooting
Spray with lubricant and let it work - you may have to spray more than
once - main thing is do not strip the screw head....try a long handled
screw driver.
Regards,
Dennis
Aug 17, 2014 | Delta Faucet Delta 474-WH Waterfall Single...
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
Jan 30, 2011 | Moen & Replacement Cartridge
I"m removing and replacing a
Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
Low pressure hot water only delta 470ddt
there is likely sediment under the spring and washer on the hot water side of the faucet under the handle. If you shut off the valves to the faucet, it is very easy to dismantle. There is an allen screw on the front of the handle to remove the handle. Under the handle there is a nut. Once you unscrew this nut there is either a ball or a cartridge )depending on the year of the faucet) that can be removed If it is the ball, then you will see two rubber washers in the base. Use your allen wrench or needle nose pliers to remove the washers and remove any sediment.
Nov 28, 2010 | Delta Faucet 470-DST Signature Diamond...
The water leaks from the top of the valve when the handle is fully opened.
You may have to put a new repair kit in faucet, but you might try tightening the adjusting nut under the handle. Loosen set screw in handle, and remove handle. There is a nut there with 4 notches in it. Delta gives you a combo allen wrench/spanner wrench for this. Try to tighten this nut. If you can't you can buy a new repair kit for this valve for about 10.00 that comes with wrench
Jun 27, 2010 | Delta Model 470: Signature Kitchen...
DELTA SINGLE HANDLE GOURMET SPRAY faucet
Hello. Actually it is not difficult to remove the faucet. If you can pull up the sink with faucet attached it will be very easy. Otherwise get under the sink with a flashlight and you will see what tools are needed. A special extendable faucet wrench from Home Depot would come in very handy. Regards. Joe
Jan 14, 2010 | Delta Cycle Rothko Rolling Bicycle Stand
We are trying to remove the handle on a delta 172 single handle kitchen faucet. The hex screw won't budge now, but we were able to get the handle a little bit loose. Now not only is the faucet dripping,...
Make sure the exact allen key is in the screw. take a small adjustable wrench, close it onto the allen key, and loose with wrench turning the allen key.
good luck
Oct 09, 2009 | Delta Faucet Delta 172-WF Waterfall Single...
Replace entire valve assembly
You can drill a small hole into the set-screw and use an easyout to extract the set screw
May 04, 2009 | Delta Faucet Delta 172-SSWF Waterfall...
Delta Faucet Delta 2457 Orleans Two Handle Kitchen Faucet with Side Spray, Chrome Logo
1,306 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
