SOURCE: error codes on electrolux ede 51760w tumble dryer
is it a sensor dry is there damp washing in there when you are testing it or is it emty as this will tell the pcb to stop as it feels no mosture in the machine regards jason
SOURCE: jlt dc05 tumble dryer fault code e50
Good Afternoon,
Sounds like you have a bad door switch, try replacing it. Let me know if this helps and thank you for using FixYa!
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Electrolux EDC5340 dryer: drum is hard to turn,
you can take off the front panel, there are screws inside the dryer door,may have two on the bottom corners and then gently pry up on the top corners with a flat tip screwdriver. disconnect the door switch and the panel is off. check to make sure the the belt is centered and you can turn the drum. hope this helped tim
SOURCE: dryer works for few minutes
E50 code is for a motor issue or main PCB fault on the motor output
side (also called E51 when the triac that is on the main control board normally shorts out due to a faulty motor).
Not easy to diagnose as a diy job, but you need to find out if the
drum rotates correctly when fully loaded. Could check this CODE LIST
Hope this helps.
Hello Baldur Thor, thanks for your inquiry!
From what you have described your Electrolux air conditioner is displaying an "E50" error code. I do not show an "E50" has a valid error code. Could you please verify which appliance you are having issues with? Additionally, you could perform a reset on your air conditioner which is disconnecting the power from it for ten minutes. If you continue to have issues please reconnect. -Matt
