Are the cooling fans coming on ? Go under the hood in the engine compartment , with the vehicle running have some one turn on the A/C , do you see and or hear the cooling fans come on ? Could be the coolant temperature gauge is bad ! How many miles on the vehicle ? Ever have water pump replaced ?
Check for a loss of system pressure.
Is there a loss of system pressure?
Go to Step 2 yes
Go to Step 3 no
Inspect and repair any faulty hose connections.
Does the engine still overheat?
Go to Step 3 yes
System OK
Check for low coolant protection (-37?°C/-34?°F).
Is there low coolant protection (-37?°C/-34?°F)?
Go to Step 4 yes
Go to Step 5 no
Test solution. Replace the coolant if necessary.
Go to Step 5 yes
System OK
5
Check the water pump belt for low tension.
Is the water pump belt tension too low?
Go to Step 6 yes
Go to Step 7 no
6
Replace the water pump belt tensioner.
Go to Step 7 yes
System OK
7
Check for an inoperative thermostat bypass.
Is the thermostat bypass inoperative?
Go to Step 8 yes
Go to Step 9 no
8
Replace the bypass.
Go to Step 9 yes
System OK
9
Check the water pump.
Is the water pump inoperative?
Go to Step 10 yes
Go to Step 11 no
10
Replace the water pump.
Go to Step 11 yes
System OK
11
Check the radiator fins for obstruction.
Are the radiator fins obstructed?
Go to Step 12 yes
Go to Step 13 no
12
Inspect and clean the radiator fans.
Go to Step 13 yes
System OK
13
Check the cooling system passage for obstruction.
Is the cooling system passage blocked?
Go to Step 14 yes
Go to Step 15 no
14
Inspect and flush the system. Reroute or replace the hose if necessary.
Go to Step 15 yes
System OK
15
Check the water pump belt for damage.
Is the water pump belt damaged?
Go to Step 16 yes
Go to Step 17 no
16
Replace the water pump belt.
Go to step 17 yes
System OK
17
Check the cooling fans.
Are the cooling fans inoperative?
Go to Step 18 yes
Go to Step 19 no
18
- Inspect the electrical connector. Replace if necessary.
- Does the engine still overheat?
Go to Step 19 yes
System OK
19
Check the throttle body circuit flow.
Is the throttle body circuit flow restricted?
Go to Step 20
Go to Step 21
20
- Inspect the orifice and associated hose. Replace if necessary.
Go to Step 21
System OK
21
Check for a stuck thermostat.
Is the thermostat stuck in the closed position?
Go to Step 22
22
Replace the thermostat.
System OK
