SOURCE: I have an Electrolux split
Fan mode only, you can control low/med/high speed. In dry mode with low fan, it cut in and off air-con for five minutes frequently.
SOURCE: i have a blizard split model 10.5 years old in a
Please understand first, air conditioning system not only cooling the area but also removing the heat. If heat in the room stays constantly, even 24 hrs running a/c couldn't cool the room.
Now, why the a/c could not cool the room or remove the heat from the room.
Check air filter, evaporator coil and blower wheel for clean. If not service the unit immediately. And also check indoor fan motor rpm. If rpm is low, replace fan capacitor. Check for gas pressure to confirm no leak or running with short of gas. It's advisable to service both indoor and out door once in 6 months at least. Otherwise, your electric bill will kill you lot. Thanks.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Error code details are goven.
