Hi Sir Wayne Foster, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Is this a serious question Wayne?Hi Sir Wayne Foster, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Ok my ciggarete lighter was first to go out,then I tried to find the fuse,but a(29)amp fuse that was blown fell to the floor. I don't know where it came from? If you could assist me I could go pick up my wife.She'd Really Appreciate it....Give me the order of the fuses left to right. I thank you....Ok my ciggarete lighter was first to go out,then I tried to find the fuse,but a(29)amp fuse that was blown fell to the floor. I don't know where it came from? If you could assist me I could go pick up my wife.She'd Really Appreciate it....Give me the order of the fuses left to right. I thank you....
Did you find the fuse that the owners manual tells you is 4 the trunk lite?? If its not the fuse and the light it has 2 B the wiring somewhere. Check the bulb socket with a volt meter to make sure you have voltage at the socket itself with the trunk hood up obviously. It could also be the actuator switch. Good luck!!
fuse under bthe dash the manuel should tell u what fuse it what changev it if not ur lite little bulbs in the daskh have blown 96 %of time its the fuse
Sounds like you may have blown out the alternator protection fuse by hooking the battery cables up backwards. How does one do that?? Check the large "MAXI" fuses in the Under hood fuse box near battery, this will be a large amperage fuse.
sorry had to laugh about the wire in his hand thing lol. does the mirror operate correctly? if so the wire may be ok to have in his hand :) as far as the lite on the front it could be a fuse. check under hood fuses to see if one blown, if they are ok get a test lite and hook to and ground sorce near the lit and unplug the lite. turn the head lites on and probe the plug. does it lite up the test lite? if so the bulb you got is defective if not then it may be a bad ground for that lite check the wires around that area to make sure there connected to the body good. try this first to see where you get to. hope this helps
COULD BE BAD BATTERY POSITIVE CABLE.BATTERY FEED WIRE FROM THE POSITIVE BATTERY CABLE BROKEN.YOU COULD HAVE POOR GROUND.YOU COULD HAVE BLOWN ALTERNATOR FUSE LINK OR FUSE BLOWN.CHECK ALTERNATOR FIELD WIRE OR BATTERY FEED WIRE FOR BROKEN OR DISCONNECTED WIRES.
Unfortunatly I don't have a owners manual....
The cig is usually hooked to the radio fuse is that on?
