Question about Hampton Bay HBLG5004 Air Conditioner
Does not seem to be as cool as when first installed.
  • 30 Answers
Not knowing the age - I'd say you have not cleaned the unit for day one ?? replace filters on a 1 month routine ( coils could be clogged )
Check your manual ( book) for the easy things first. dog and cat hair can build up over time and you don't see it ( on the cooling coil) Filters cost 2 bucks and a service call can cost 100.00 and more ( P & L)
Posted on Jul 18, 2009
I have installed RTH8580WF thermostat for heat pump in my condo. I have R O Y G and I added wire. It seems it works opposite with 170=2 cools when heat on and teas when cool on.
Press the FAN & the up arrow @ the same time to get into installation programming. Follow the set up numbers correlating to options in the install instructions...Make sure it is programmed for heat pump & if you have Auxillary heat. Hit Next until you get to the reversing valve position O or B ( reversing valve energized in a call for heat or cool) and switch it to the opposite of what is in the current program. Hit Done & you should be good.
Oct 23, 2013 | Honeywell RTH8580WF WiFi Thermostat
I have a SSX140241A - 2 Ton 14 SEER R410A Goodman Air Conditioner Unit with a CAPF1824A6 - Goodman 1.5 to 2 Ton Cased Evaporator Coil. The coil came with a size 59 piston and the outside unit had a size 55...
No, it simply has to do with the fact that the conditions are exceeding the innate capabilities of the unit. Need more refrigerant and larger condenser and evaporator. Basically, a bigger, more powerful unit for the conditions encountered.
Sep 22, 2017 | Heating & Cooling
My air conditioner stops cooling. Occasionally, it will just function on fan mode even though I confirm that it is on cool mode. Warm air comes out even on the absolute coldest setting. I have to turn it...
If after reset the A/C cools then the fault seems related to the thermostat or the cut off pressure switch or load cut off.
However is there is no cooling at all the compressor and the gas pressure- check for leak if gas is absent.- must be checked .
If compressor is suspect you must check the estimate and decide whether it seems better to scrap and buy a new one.
May 18, 2011 | LG ZW6500R Air Conditioner
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
Refrigerator will not cool . the freezer is freezing but it seems to be building up frost.
You have an auto-defrost issue. Cooling the fridg side comes from the freezer side. If you see frost on the inside back of the freezer side, it's clogging the cooling vent to the fridge side. You need to have the defrost parts replaced. Parts cost less than $50. Installation is around $250.
Jul 13, 2009 | Whirlpool ED2FHEXN Side by Side...
Noisy and inconsistent cooling
It could be that there is a problem with the Thermostat\low voltage switching. Some heat pumps have reversing valves activated for cooling , sometimes for heating. Whoever installed this for you is totally responsible for your unit still. There can be a number of things going wrong, like no filter drier in stalled and sporatically clogging the refrigerant and making a lot of noise. Call the installer back.
Jul 13, 2009 | Heating & Cooling
Unit never used--won't cool
I would call and get a couple other estimates. If it has never been used, the compressor is probably not bad.
Oct 21, 2008 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
239 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
