I put a 25 watt bulb in my max 15 watt machine by accident and i was on a a few minutes then it just clicked off. I went to start sewing and pushed the pedal and nothing happened and the bulb has gone off. Is it a blow fuse? How do I replace it?
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
SOURCE: My foot pedal is really hot
Based on your description and since your sewing machine is older, the motor inside your machine is probably drawing more current to maintain the same output power and all that current is passing thru the foot operated switch.. What that means is that your motor windings may be breaking down from age and use or the contacts within the footswitch may be getting carbon on them from passing more current than the original design called for and becoming resistive ( which equates to it getting hot). I suggest you discontinue using it until you have it maintenanced to make sure you aren't risking a shock or fire hazard. Sight unseen, it's difficult to draw any other conclusion.
Regards,
Rick
SOURCE: Today the machine started sewing by itself! My
There is a supressor, usually in the foot control that has burnt out.
Not dangerous, quite a;arming tho'
If you can remove the burnt unit yourself that's fine, but if you are in any doubt, ask a service centre for a quote to remove ot for you, or a qualified friend etc.....it is not essential, just reduces interference on TV and Radio while you sew in the same house.
It is mains power, so don't fool with things you don't understand.
SOURCE: sewing machine stops sews a minute slows down or stops then starts up
I suggest having the machine checked at a sewing machine shop
to see if there is something wrong with the motor, or the foot pedal
but first check to make sure the power cord & foot pedal are
connected correctly
