Question about Husqvarna Chain Saw 20" Bar
I REMOVED THE SIDE COVER ON A HUSQUAVARNA 41 TO CLEAN THE SAW. THIS COVER ALSO HOUSES THE CHAIN BRAKE. I PUSHED THE CHAIN BRAKE HANDLE FORWARD TO BETTER CLEAN IT. (CHAIN BRAKE ON) NOW I CAN'T GET THE HANDLE BACK TO RELEASE THE BRAKE. IS THERE A TRICK TO DOING THIS?
  • 1 more comment
  • gtm452 Jul 17, 2009
    I CAN'T SPOT ANY OBVIOUS RELEASE FOR IT. I'M NOT SURE THAT I KNOW WHAT I AM LOOKING FOR. THE HANDLE IS ALL THE WAY FORWARD AND WILL NOT PULL BACK NO MATTER HOW MUCH FORCE THAT I APPLY. ANY SUGGESTIONS?
    I WAS ADVISED TO LOOK FOR A BRAKE RELEASE AND I DID NOT SEE ANY THING OBVIOUS TO DO THIS. CAN YOU TELL ME WHAT I AM LOOKING FOR? THE HANDLE IS STUCK ALL THE WAY FORWARD AND WILL NOT PULL BACK NO MATTER HOW MUCH FORCE IS APPLIED
  • gtm452 Jul 18, 2009
    THIS LOOKS LIKE WHAT I NEED. THE PICTURES AND PRINT ARE TO SMALL TO SEE IN THIS FORMAT. IT WOULD BE GREAT IF YOU COULD E-MAIL THIS TO GTM452@AOL.COM. THANKS!
  • 336 Answers
There is trick in release the chain brake, just pull the handle then it should be released. If not, then something might have been stuck up causing the brake not to be released. I suggest you dismantle the brake to trouble shoot what is happening there. Here is the procedure, I hope you can see it clearly if not send me your email address then I'll give you a copy of service manual. I hope this helps.
Posted on Jul 17, 2009
    President:
  • 2,777 Answers
You will need to release the chain brake, there should be a release for it.... let me know if you can spot it or not. It will need to be put back into the original position for the cover to fit on..
Let me know, thanks
Tim
  • Tim Grayson
    Tim Grayson Jul 17, 2009
    Since you rated my answer poorly I can't answer any further.
Install side cover on 455 rancher with chain break
Problem is you removed side cover with chain brake closed. You must open the chain brake to re-install the cover. You can do it with the handle. Put the side cover into position, put the handle into the fitting on the side cover. push the handle forward until you feel the "3" point connector engage. apply pressure to the handle and pull back until the side chain brake "Pops" open. Your Husqvarna dealer has a tool to open the chain brake if you are unable to get it open. Takes about 5 mins.
Feb 10, 2014 | Husqvarna Garden
Tip
How to get the chain brake reset so ou can get the sidecover back on
If you have removed the sideplate on your chainsaw with the chain brake in the locked position, you will have a very hard time getting it back on without destroying the brake band. If you have done this try this solution. First remove the bar and chain fronm the saw, then start putting the side cover on, use one of the nuts on the front screw.As it comes in contact with the ratcheting part of the hand break make sure you push the chain brake handle forward while tightening the front nut I mentioned. when the nut is snug, pull the brake handle back to reset the brake, You will hear it click into place. then remove the side cover and re install the bar and chain. your good to go/
on Dec 15, 2009 | Garden
Chain saw brake on husquvarna model 41
To replace the brake band do as follows, remove the bar nuts and take the brake away from the saw, engae the brake to remove as much tention off the internall spring by pushing the hand guard fully forward, remove the allen screw securing the hand guard, do not remove the e clip and pin from the hand guard, tap out the pivot collers and remove the hand guard, remove the cross head screws securing the spring cover, carefully remove the spring from under neath, tap out the silver pivot pin from the knee link activating arm, use a puch from the other side of the brake to remove the roll pin securing the other end of the band, with the band out remove the screw securing the band to the knee link, install the knee link to a new brake band, re fit the roll pin in the band and re fit into the cover, insert the spring, this will have to be compressed to get it back in, re fit the spring cover, you need now to load the brake, fit the hand guard onto the cover, insert a conical puch through the hand guard and cover to enable you to pivot the hand guard back and load the brake, now fit the hand guard properly onto the cover and re fit the collors and screws.
Jul 26, 2012 | Husqvarna Garden
HUSQVARNA MODEL 435 CHAIN SAW.....BRAND NEW IN JUNE...NEVER USED....WITH BLADE, CHAIN, AND SIDE COVER (TENSIONER ASSY) REMOVED, IT RUNS FINE......WHEN CHAIN BAR , CHAIN, AND COVER ARE REINSTALLED AND...
There is a number of ways to re load the brake, you can either remove the clutch and sprocket, the brake will then go back onto the saw enabling you to use the hand guard on the saw to load the brake ( to remove the clutch, there are two cut a ways in the clutch centre designed to enter a flat screw driver into, then strike with a suitable hammer to remove, it is a left hand thread ) or you can remove the hand guard from the saw and use this as a tool to re load the brake, or you can clamp the cover in a vice ( be carefull not to damage the cover ) then use a strudy pair of pliers or grips in the three legged loading mechanism and turn it to load the brake.
Dec 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I can't unlock the blade.
Do you mean the chain won't move, or you can't get the blade off? The chain brake must be off to allow the chain to move. The chain brake handle has a housing that engages a gear attached to the chain brake inside the cover where the blade is attached. The brake must be off to remove the cover (usually held on by two nuts). The blade tension screw should be loosened to allow the blade to be removed, then retightened when replacing the blade. Tightening it pushes the blade out from the saw, so if it is tight, you won't be able to remove the blade. Hope this helps.
Aug 27, 2011 | Garden
Trying to fit bar and chain on a new 445.can not replace clutch cover after following instructions closely.it seems brake is on. WOULD REALLY APPRECIATE HELP. THANKS.
You'll definitely have to unlock the chain brake to get the cover back on. You should be able to unlock it by pushing the chain brake handle forward, toward the bar and chain when mounted on the saw.
Oct 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How do I expand the spring that goes around the clutch so I can put the side cover back on?
that spring is the clutch brake if it not broken all you have to do is set the handle in the off setting by pushing it forward, them put the side cover back on.
Aug 23, 2010 | Husqvarna Chain Saw 20" Bar
Starts but chain wont turn. and white smoke comes out the side where chain is. is it the clutch thats burn out?
Grasp the forward most upper handle (hand guard), move it forward, did it click? If no the brake is released. Pull it aft until the brake latches open (clicks), may require some grunt at rear extreme.
Remove the clutch cover, bar and chain. Start the saw, does it still smoke? Yes post back below, no reassemble your saw, ensure the brake is open. Start teh saw. Smoke? If yes post back below.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 25, 2010 | Garden
Brake mechanism stuck in locked position Husqvarn 142 chainsaw
COMMON PROBLEM----you have to push it forward you wont break it, it is much stronger than you think you just have to hold the cover section and push or lever the bar forward, it will go. I believe one Ace hardware guy had some sort lever wrench made up just to do this for all the people like you. so muscle up and do it "youdoit "
Sep 24, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
CHAINSAW BRAKE LOCKED ON HUSQVARNA 455 RANCHER HELP PLEASE?
I used applman08's solution. A few pointers:
0. This problem occurs when you take off the side cover while the brake is set. So after you fix this, don't do that again.
1. When removing the clutch, place the screwdriver in the notch next to where it says "off" and tilt the screwdriver down so that when you strike it you are applying a clockwise shock force that is almost horizontal (assuming your 455 is on its side).
2. DO NOT remove the spring! There is a plastic housing that basically holds the brake mechanism in place (secured by 4 screws). If you take that apart, and then take out the spring, you will be learning how the brake works and spending some time compressing that spring and getting it back in. You'll have to come up with something clever to get the spring in depending on tools available.
3. Going back to 1. - get that clutch off, put the side cover back on, getting that brake lever lined up with the very-difficult-to-grab three-toothed mechanism for engaging the spring. Tighten down the side cover, or hold it snug with one hand while you lever the brake handle with the other. You will hear a satisfying snap as the braking mechanism (with the spring I told you not to mess with) resets.
Note: You can probably reset the braking mechanism by manually turning that three toothed gizmo but it's really hard to grab and the brake handle fits it perfectly. The key is you've got to turn that about 60 degrees.
Good luck, this was an annoying problem.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
141 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
