Question about Sport & Outdoor - Others
The screen tent looks just like the "Westview Screen Arbor" one
    President:
  • 2,777 Answers
What kind of screen are you referring to? Not sure what your problem is exactly?
THanks
Tim
Posted on Jul 17, 2009
Instruction for 12 x12 screen tent
Amy, 12 x12 screen tent setup. Check the attached links,instruction and guides, you can also try Google search your make and model# instructions. Good luck. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://store.eurekatent.com/media/document/SCREENHSE09IM.pdf
Screen Tent Instructions eHow
http://www.shelterlogic.com/support/manuals
12 x12 screen tent instructions Google Search
Aug 27, 2016 | Sport & Outdoor - Others
I need instructions for 89034 17x15 moab
Instructions
  1. Select a flat camping area and clean the area of sticks and rocks. Remove the tent from the bag and spread out the tent body with the floor on the ground. Assemble the tent poles by connecting the attached sections at the ferrules. Set the poles on the ground and separate by size.
  2. Locate the three long sleeves on the tent body. One sleeve is horizontal over the screen room and the other two cross the main tent body to create an "X". Locate the three long poles and slide one through each sleeve. Place the corresponding pins in the end of the poles. The poles will flex and erect the tent body. This step is best attempted with two or more people.
  3. Attach the clips to the exposed sections of the tent poles. The clips are attached to the ten fabric and will add rigidity to the tent. Locate the next largest pole and insert it through the sleeve on the screen house. Locate the metal grommets where the screen room meets the main tent and place each end of the pole in a grommet.
  4. Locate the two smallest poles. These are for the side rooms. Insert one pole through each of the side room sleeves. Attach the ferrule of one steel pole to each end of the side room pole. Insert the corresponding pins in the end of the upright poles to support the side rooms.
  5. Pull on each end of the tent to ensure the floor is tight. Use a rock to pound stakes through the ground loops on the tent. Place the floor mat in front of the screen room door and use stakes to secure the mat to the ground.
  6. Place the fly on the tent and make adjustments until the shape of the fly matches the tent. The fly will only cover the top of the screen room and the entire body of the main tent. Locate the D-rings on the base of the tent and attach the fly hooks to the closest rings. This will tighten the fly to the tent body.
  7. Locate the guy ropes on the fly. Pull the ropes to the ground at an angle and pound stakes through the loops to anchor the tent to the ground.
Read more : http://www.ehow.com/how_8092535_directions-ridgeway-tent-kelty.html
Jul 23, 2015 | Baby Gear
I need the inside measurements to see if 4 cots will fit inside.
This is a dog-gone big tent, even if the erected size works out to only something like 8x12 (leaving aside the screen porch) that will easily fit 4 cots 2x7 ft each. You are more likely to have problems finding tent sites large enough (flat) to allow it to be set up properly.
Apr 13, 2015 | Magellan Outdoors Yukon II Cabin Tent
Where can i get a part for my swissgear screen tent?
Typically the Swiss gear store (online) will carry that part, check local pawnshops, Craigslist, and other second hand places fir your style tent, it never hurts to have a back up! But Che your local REI and sportsmanship, dicks, ect.
Jul 09, 2013 | Camping, Backpacking & Hiking
2000 Great Basin
Thanks When you're ready to step up to the world's finest <A HREF="http://detectorsforgold.com/gold/category/metal-detectors-gold">metal detectors</a>, you're ready for Bounty Hunter. And get set to dig deep. Not into your pocket, but into the ground. That's because genuine<A HREF="http://detectorsforgold.com/gold/bounty-hunter-tracker-iv-metal-detector.html">bounty hunter tracker iv</a> can pick out virtually any metal object from any terrain - yet even with all their features, they are surprisingly affordable.
May 03, 2013 | Sport & Outdoor - Others
Assembly instructions for 8 person dome tent with screen house.
You might be able to get help at bulk@avidoutdoors.com but Avid sells tents by many manufacturers.
Aug 25, 2012 | Coleman Camping, Backpacking & Hiking
How to set up a Diamond Brand screen tent
ASk Diamond at:
145 Cane Creek Industrial Park Rd., Suite 100 • Fletcher, NC 28732
phone - (828) 684.9848 • fax - (828) 687.0965
wgay@diamondbrand.com
Aug 12, 2012 | Camping, Backpacking & Hiking
Need instructions for my Avid Screen Tent, Item # 2086
What size and kind of poles for the screen room?
May 13, 2012 | Sport & Outdoor - Others
How do i put up an americana arbor screen house. I lost the instructions
the top pole go in the order 123, the outer box is 454, and the big poles are the legs
Aug 13, 2011 | Texsport Big Sky Room Family 01327 Tent
I have a greatland tent item #15710. This is a two room tent (not dome) with a screened porch. The poles have numbers and some numbers are blue and some red. I cannot identify whether the numbers go in...
I am looking for a manual for Greatland Outdoors 2 room tent with screen porch item #15710, however, I guessed how the poles go together. I set up the tent by myself, but I recommend 2 people or more, especially if it is windy.
Start by stretching out the bottom of the tent into a square, and stake all of the perimeter tentloops to the ground, starting with the corners, with the stakes directed at a 30 to 45 degree angle under the tent, so the tent cannot easily pull them back out. Leave the yellow cords attached to the tentloops loose, so you can use the cords to help pull up the stakes when you take down the tent.
Now assemble the poles going through the loops across the front of the screen porch. Insert one end of a pole #1 into a pole #2 and thread them through the loops over the entrance to the screen porch. Put the long end of a curved pole #3 through the loops starting from one side, and attach to either side of the 1/#2 you made. Put the long end of another #3 through the loops starting from the other side and attach to the loose end of the #1/#2. You should tie the loose green cords on each corner of the sceen porch to the silver metal rings at the curved end of each #3.
Later, you will do the exact same assembly with a #3 on each side of a #1/#2 for the poles going across the back of the tent and the poles going through the pocket across the middle/top of the tent.
Now insert the small end of pole #4 into the curved end of a #3, then insert the small end of a #5 into the open end of the #4. There should be a rubber foot on the bottom of the #5 pole. Do the same thing for the other side of the porch. With help, you should be able to prop up the front of the sceen porch, pulling aganst the stakes holding the rear floor of the tent, and place the rubber feet of the #5 poles close to the center loops of the floor on each side.
Now prepare the #1/#2 poles for the rear, and attach a #3 to each side and tie the loose green cords to the silver rings on the short ends of the #3s. Prepare a #4/#5 pole the same as the front, and prop up the back of the tent, putting the feet near the side loops of the floor which are about 1/3 from the rear of the tent.
Make another #1/#2/#3, and push it through the pocket across the middle of the tent, and connect the last #3 from the other side. The side supports for the middle are pole #8 with the white clamp on the bottom, and pole #7 slid into pole #8 (The #7 was scraped off both of mine). Leave the #7 mostly inserted into the #8 until after the center is lifted up. The #6 goes on top of #7, and insert the #6 into the curved end of the #3 poles which are already in the center pocket, and tie the loose green cords to the silver rings at the short end on each of the #3s. Now lift up the center with someone helping on the other side, and put the feet of the #8 into or near the yellow loops at the center of each side. Loosen the white clamps and extend the #7 poles until the peak of the tent is at proper height.
Move the feet of the #5 poles closer to the tent, until all is tight, and you should be done!
Jul 21, 2009 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
