Question about Dryers
Gas dryer runs but no fame to heat it up - Dryers
    President:
  • 512 Answers
You have a bad thermo switch, unplug, open back of dryer, switches are quarter size round and two wires hooked to them, also on is thin and 2" long sually white with two wires ooked to it. Check these with a tester, just like you test a fuse, from one side to the other. When you find the bad one, jump from one side to the other, plug dryer in and see if it works, it will if switch is bad. Then replace bad one. Do not leave jumped, if dryer overheats it will not shut off and could cause a fire. Jumping is just for test only.
Posted on Jul 17, 2009
  • 864 Answers
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Samsung gas dryer model DVCBGW/XAA
something may be kicking the flame off and not allowing it to burn consistantly, use multi meter and check the flame sensor, the glow bar or flame igniter, and the gas valve and coils? I suspect the coils are going bad and not putting out the right gas pressure need to keep fame burning? not sure the rating but I think its bout 1200 oms per coil? anything less is insufficient
Jul 08, 2014 | Samsung Dryers
My Magtag dryer model#DG612 (series 05) stopped producing heat to dry the clothes. There was a flame for approx two minutes, and then the fame went out. What can I do to fix this problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 28, 2011 | Dryers
Dryer runs fine but heating unit will not ignite
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Kenmore dryer, the dry runs, but does not heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
Runs but no heat
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
LG DLG 2526W dryer running but no heat
heatman101
May 22, 2010 | LG D2526 Gas Dryer
My dryer runs, but doesn't heat up...
heatman101
May 19, 2010 | Whirlpool LER4634J Electric Dryer
Ignitor? dryer runs through cycles, but NO heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
gfgf
Oct 16, 2009 | GE DBL333GB Gas Dryer
Trying to access gas valve on whirpool estates dryer
if your talking bout a dryer then yes. standard front loader? have to take off panel and remove tub. let me know what kind of dryer and i can tell you how to remove panel
Jun 22, 2009 | Dryers
Alantis Gas Dryer MDG7600AWW not staying hot or lit
All you need to do is replace those pesky intermittant coils
aab79a0.jpgI wote a short essay on this problem. To keep from being redundant I have it HERE
Mar 02, 2009 | Maytag Dryers
Dryers Logo
171 people viewed this question
Top Dryers Experts
