Question about Singer CE-100 Futura Computerized Sewing Machine
Viking sewing machine 545 bobbin stuck on rewind
For viking sewing machine 545 I wound the bobbin and now I can not seem to remove the bobbin??
  • jccoughlin Jul 18, 2009
    Thanks, it would seem that it should just pull off the shaft but it won't. Been pulling in all different ways and it just will not budge. thanks anyway.
Most machines you slide the bobbin winder to the right to wind and then back to the left when your done to remove. Just making sure.... you did move it back to the left?
Posted on Jul 28, 2009
    Brigadier General:
  • 4,088 Answers
It should just pull off of the winder shaft. There is a small spring that sticks out from the shaft to hold the bobbin in place (at least on my wife's Viking which is a different model number than yours). Is there a release button somewhere near?
Posted on Jul 17, 2009
I just inherited another Huqvarna (this is a model 630). It was working great until I wound a bobbin on it. After I removed the filled bobbin the machine won't move the needle up and down (but the bobbin...
I do not know the Husqvarna Viking 630. However, I have used the Viking 6690 and it has a similar on-the-side bobbin winding routine. I suspect that you failed to move the bobbin winding mechanism back into the sewing position. Look closely at the area around the bobbin winding spindle. It looks like there is a lever below the spindle. Does this need to be moved or rotated? Double check the steps in the manual and check that you did the opposite steps of preparing to wind the bobbin.
On the 6690, you pull out a knob after removing the bobbin. (You push this piece in and put the bobbin onto the now exposed spindle for winding.)
I hope this helps.
Dec 21, 2014 | Sewing Machines
When rewinding bobbin on the 415, it is stuck & can't get it off the machine
Some how the bobbin got wound too tight. The thread must have been caught along it's path or something. You will have to unwind the thread off the stuck bobbin. Once enough thread is off the bobbin it should pull off. After that, throw that bobbin in the trash, it is now deformed and most likely will not work anymore. If you wind your bobbins with the machine threaded always make sure you have your presser foot up and Always use a metal foot.
Apr 04, 2014 | Husqvarna Freesia 415
Handwheel stuck
most likely the bobbin thread is wound around the components.
remove the bobbin and check for a mass of thread cut it all away and remove every last bit then it should work
Dec 28, 2013 | Janome Hello Kitty 11706 Mechanical Sewing...
The bobbin on my Husqvarna sewing machine (Viking 100) is stuck on the bobbon winder
If your bobbin still has thread on it, remove it by hand and then try to pull the bobbin off the winder.
Oct 14, 2010 | Husqvarna Viking 1
Bobin thread wads up. I have a viking mega quilter and frame. I have removed all the threads several times, but each time I try to quilt, the cruise control can only move about an inch, and the bobbin has...
just a thought but maybe your bobbin thread is wound on to loose,try to rewind it holding onto the thread to give a tigher tension while going onto the bobbin
Dec 20, 2009 | Husqvarna Viking 1
Have a husquvarna viking 200 machine and the bobbin has stuck on the mechanism while I tried to remove it after the bobbin was filled. Have pulled and pulled and it simplyu will not come off. Thanks for...
I'm assuming you are talking about the rewinding mechanism on top. There are grooves in the bobbin which fit on to the rewinding spindle that holds the two together while the bobbin fills. It may be they have gotten out of synch or the bobbin is a non-standard Husqvarna Viking bobbin for that machine. These usually use green bobbins but they have come out with new colors but all have the Husqvarna logo on the bobbin -- an H. I would try to wiggle it slightly to try to remove it. If still will not come off, try popping it off with a flat head screw driver but be sure to put a folded towel under the screwdriver so that you don't damage the molding of the machine. If you still are unable to get it off, recommend taking it to an authorized Husqvarna Viking dealer. A list of dealers near you is available at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 26, 2009 | Husqvarna Viking 1
Bobbin stuck on winder
Sometimes when a bobbin is wound very fast the plastic gets hot and misshapen, and you can't remove it. Nothing for it but to break the bobbin - it's useless now anyway even if you could get it off in one piece. Pull off as much thread as you can and use pliers or something similar to break enough of the bobbin so it will come off. You need to take care not to let little broken pieces fall into the machine mechanism and take care not to yank too hard on the bobbin winder spindle. If all this scares you too much, take the machine to your dealer for help. And remember to slow the machine down a click or two when you wind bobbins! (It may be of some comfort to you to know that every user of plastic bobbins has done this at some time!)
Jul 21, 2009 | Husqvarna Viking 1
I have a viking Iris sewing and embroidery machine and the bobbin thread is bunching up underneath so then the thread breaks
When I had that happen, it turned out that I had not wound the bobbin thread correctly (it was not wound tight and smooth enough). Wound a new bobbin from scratch, and all worked fine.
Feb 18, 2009 | Husqvarna Rose
Bobbin does not wind all the way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Feb 08, 2009 | Husqvarna Lily 540 and 550
Singer CE-100 Futura Computerized Sewing Machine Logo
264 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
