Question about Casio Exilim EX-S880 Digital Camera
My exilim camera is stuck on the picture won't
I was viewing pics on my exilim youtube capture mode camera and it got stuck on one picture. I can't turn the camera off, can't move to next picture. I took out the card and it still wouldn't shut off. Thankfully the pics are still on the card.
Can I
Posted on Jul 25, 2009
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
I am from bangladesh the problem associated with my camera is that the display dont show the view of the subject that iI want to capture and the resultant is the no picture only shows the black sheet in...
The S2 IS is a very nice camera, but is known to be susceptible to stuck shutter problems. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 12, 2011 | Canon PowerShot S2 IS Digital Camera
The view finder or screen are black. The lens moves out when the camera is powered on, I can hear the shutter click when pushed; the telephoto is moving; I have all the settings show on the screen when...
I know it may sound like the shutter is moving, but you're going to have to actually look down the lens barrel to confirm it's actually moving, and not just producing a sound effect from the camera. Also keep in mind Canon's SX IS series cameras are notorious for the following problem (fantastic cameras otherwise).
Oct 31, 2010 | Canon PowerShot S3 IS Digital Camera
Pics are blank in viewer
there are many reasons that no picture is displayed:
1. there is no picture in the first place. (camera lens closed when picture was taken)
2. you are not on display mode (toggle to display mode not "take picture" or capture mode)
3. defective memory card.
4. you are on display mode but on another sub-mode which does not display pics... (toggle to display, details, etc...)
Aug 24, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Not capturing pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Feb 12, 2010 | Canon PowerShot A530 Digital Camera
I have a cannon sd1000 , bought 1 month back. suddenly its stopped capturing pictures. i.e while in shot mode the display is black and not showing and capturing the image.but able to access al the menus....
Jul 17, 2009 | Canon PowerShot SD1000 Digital Camera
When i capture a pic in day light than picture will come faded and when i capture in night it comes nice one my camera model is exilim ex z60
make sure the camera's settings are set to normal, since, the lens might be sensitive to daylight. You can actually change this at the settings, and, you said that it works fine at night or at dark areas? Yeah, the lens could be sensitive to bright lights! Simply adjust the sensitivity and you're all set!
Jun 25, 2009 | Casio Exilim EX-Z60 6MP Digital Camera...
How do I see my pictures in macro mode? If shows
click on the " flower" icon on the dial wheel to select the macro mode and then shoot normally. also, do remember to return to normal mode by pressing the flower icon again... or else you might end up getting blurry images.
Feb 18, 2009 | Canon PowerShot SX10 IS Digital Camera
Cannoot see through the lens ??
CCD sensor is faulty ( see enclosed pic) and so no image is generated in capture mode. See if the agents will repair this fault ( as this is manufactiring fault ) free of charge ; something Sony, Canon and Nikon do .7ea4a6c.jpg
Nov 05, 2008 | Casio Exilim EX-Z57 Digital Camera
Casio Exilim EX-S880 Digital Camera Logo
64 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
