Question about Windchaser FTR163 SensorFan Stand (Pedestal)
Fan blade will not turn but can hear motor - Windchaser FTR163 SensorFan Stand (Pedestal)
    President:
  • 512 Answers
I hate to give you bad news but the brushes are worn and motor will not spin anymore. Fan is a good parts donor.
Posted on Jul 17, 2009
Ceiling fan off track
Might have broken the flywheel if this fan has one. The flywheel is the is the round rubber wheel that the blades attach to. If I knew the model of the fan I would know if it has a flywheel.
Aug 31, 2013 | Casablanca Fan Dryers
My air conditioner tries to turn on, air comes out of vents but isn't cold, and outside the blades on the AC unit are not spinning. I hear a noise when it tries to turn on but they don't start...
Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor
Jun 17, 2011 | Heating & Cooling
I have a model 5BS520C. The light works but when I pull the chain for the fan, I hear the sound of three speeds but the blades do not turn. ed.pfohl@gmail.com
Here some toubleshooting:
Problem 1. Fan will not start.
Probable Cause
1. Fuse or circuit breaker blown.
2. Loose power line connections to the fan, or loose wire connections in the switch housing.
3. Reversing switch in neutral position.
Suggested Remedy
1. Check main and branch circuit fuses or circuit breakers.
2. Check line wire connections to fan and switch wire connections in the switch housing.
3. Make sure reversing switch position is all the way to one side.
WARNING: Make sure main power is turned off.
Problem 2. Fan sounds noisy.
Probable Cause
1. Blades not attached to fan.
2. Loose screws in motor housing.
3. Screws securing fan blade flanges to motor hub are loose.
4. Switch housing binding against the blade hub.
5. Wire connectors inside switch housing rattling.
6. Screws holding blades to flanges are loose.
Suggested Remedy
1. Attach blades to fan before operating.
2. Check to make sure all screws in motor housing are snug (not over-tight).
3. Check to make sure the screws which attach the fan flanges to the motor hub are tight.
4. Check to make sure that the switch housing does not bind against the blade hub.
5. Check to make sure wire connectors in switch housing are not rattling against each other or against the interior wall of the witch housing.
6. Tighten screws securely.
Problem 3. Fan wobbles
Probable Cause
1. Setscrew in motor coupling is loose.
2. Setscrew in the hanger ball/downrod assembly is loose.
4. Fan blade flanges not seated properly.
5. Hanger bracket and/or outlet box is not securely fastened.
6. Fan blades could be out of balance.
Suggested Remedy
1. Tighten the setscrew in the motor coupling.
2. Tighten the setscrew in the hanger ball/downrod assembly.
3. Check to be sure screws which attach the fan blade to motor hub are tight.
4. Check to be sure the fan blade flanges seat firmly and uniformly to the surface of the motor hub. If flanges are seated incorrectly, loosen the flange screws and retighten.
5. Tighten the hanger bracket screws to the outlet box, and/or secure outlet box.
6. Interchanging an adjacent (side-by-side) blade pair can redistribute the weight and result in smoother operation.
WARNING: FOR YOUR OWN SAFETY TURN OFF POWER AT FUSE BOX OR CIRCUIT BREAKER BEFORE TROUBLESHOOTING YOUR FAN!!!
Hope helps.
Sep 02, 2010 | Monte Carlo Dryers
Remote control works the light on my Hunter ceiling fan but blades do not move
Can you hear the motor run even though the blades are not turning? If so, the manifold/flywheel may be bad and perhaps have broken away from the motor shaft.
Aug 28, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
Motor Humming but blades not running
Hi m.. if this is a new installation, look up at the area where the blades attach and be sure that you have removed all the black rubber packing stops. If this has been running and now does not , then you probably have a bad capacitor on the motor.
May 02, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Fan won't turn, only when power is ON
The motor windings sre shorted to each other , the motor is bad
Dec 31, 2009 | Master Heaters BLP375AT
Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Sep 12, 2009 | Windchaser 3-way Oscillating Fan
The fan blades do not turn but the fan motor can
speed switch is no good, the one attached to the pull cord. replace
Jul 09, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Blades will not turn
The motor probally damaged while you are moving the fan to the new house.
Jul 06, 2009 | Casa Vieja Probe Brushed Nickel Ceiling...
Fan
I would advise taking the fan cover off and the blade off of the motor and cleaning it. (Make sure its unplugged when you do this.) Maybe hair and dust has gathered around the motor and the blade. This would make the motor have to work harder, especially if stuff is wound around the motor. Good Luck.
Apr 16, 2008 | Dryers
Windchaser FTR163 SensorFan Stand (Pedestal) Logo
372 people viewed this question
Top Windchaser Dryers Experts
john h
Vernon Taylor
Are you a Windchaser Dryer Expert? Answer questions, earn points and help others
