Question about LG KC550 Triband GSM 5MP Camera MP3 Phone Black
Synchronising Phone Calendar With Outook
I'm trying to synchronise my new LG KC550 with my PC Outlook account which contains a lot of data. I get a message saying that my phone memory is full, and it only seems to store 100 entries. Is there any way to set parameters, e.g. so only last 1 month and next 2 months worth of Outlook data will be synchronised? I used to get round limited Calendar space on my previous phone, a Sony Ericsson w580i, by only synchronising appointments in this time window, and deleting older appointments from my Calendar. I then relied on Outlook as my 'master copy'.
How do i sync my htc hd7 phone (windows mobile) with outlook xp
I have Outlook 2010 client on my PC. My ISP mail account is forwarded to Outlook via POP3 mail account. I also have a gmail account to which I forward all mail to from my ISP mail address. My gmail calendar is bi-directionally synchronised to my Outlook calendar using 'Google Calendar Sync' and likewise my gmail contacts are bi-directionally synchronised to my Outlook contacts using 'Go Contact Sync'. then it was a simple matter on my Windows Phone 7 to create a Google mail account to my gmail account. I can create contacts, calendar entries in either Outlook, Gmail or my phone and they are all sync'd with each other. 'Google Calendar Sync' and 'Go Contact Sync'' are free downloads.
Sep 22, 2011 | HTC HD7 Cell Phone
Synchronising with Outlook 2007
Older versions of ActiveSync do not work with Outlook 2007. You'll need to download ActiveSync 4.5 here: http://www.microsoft.com/windowsmobile/activesync/activesync45.mspx
It should work fine once you get the newest version.
Dyllan
Nov 05, 2007 | Computers & Internet
I want to connat have I tect my mobilephone by blue tooth with my PC. Who do? Thanks for answer.
If your PC is NOT already Bluetooth enabled, you will need to purchase a USB Bluetooth Dongle
If your PC is already Bluetooth enabled,
On your phone, turn on the Bluetooth wireless feature
1. In Menu mode, select Applications ? Bluetooth.
2. Select the circle in the centre to turn on the Bluetooth wireless feature.
3. To allow other devices to locate your phone, select Settings ? On under My phone's
visibility ? a visibility option ? Save.
If you selected Custom, set duration that your phone is visible.
4. Select Save
Synchronise data
Learn to synchronise contacts, calendar, tasks, and
memos with the web server you have specified.
Create a synchronisation profile
1. In Menu mode, select Applications ? Synchronise.
2. Press and specify profile parameters (Tell it what program -Outlook- and what data -contacts - email - calendar - you want to sync).
3. When you are finished, press .Start synchronisation
2. Select a synchronisation profile.
3. Press to start synchronisation with the web server you have specified.
That should more or less do it. Let me know if you need more information.
May 15, 2011 | Samsung Star GT-S5233 Cell Phone
Synchronise my microsoft outlook messages with my E71
E71 does not sync email , only contacts , Calendar and notes settings . YOu can set it up to receive email so you can check your emails on the go
Feb 23, 2009 | Nokia E71 Smartphone
LG Viewty pc connection problems
I had the same problem. It was caused by the phone waiting for the date to be entered (even though it was already done). To get over the problem click on the multitask icon on the phone (top right). If anything is running other than "Home Screen" and "Menu" click on the application and close it. PC synchronisation should strat to work now.
Dec 30, 2008 | LG KU990 Viewty
SYNC LGKU990 to PC
This is what sorted it out for me.
When you go through the connection wizard on the LG PC Suite take note of the port number that it is using.
Then go to device manager(for win xp go to start/control panel/system, click on the Hardware tab then device manger) on your pc. Expand Ports(COM & LPT) and right click on LGE Mobile USB Serial Port and select properties. Take note of what port is indicated in brackets. Go to the Port Settings tab and select advanced. Change the com port number to what LG PC suite was using. Select OK, OK and try connecting again with the Wizard and see if you can transfer data etc
Let me know if that helped.
Sep 04, 2008 | LG KU990 Viewty
Problem with SAMSUNG SGH G600
Like i said earlier for 5 dollars i will send anyone a copy of samsungs pc suite. this incredible disc will have all sorts of wallpaper ringtone but most importantly will allow your phone to do what it was designed to do and that is synchronise with your pc so you can transfer files back and forth no problem. paypal 5 dollars to cadmansteve2000@yahoo.com and i will burn the cd and get it in the mail immediatly. be sure you match contact info with payment so they don't get confused.
Thanks and be sure you get a usb cable for your phone.
Jan 17, 2008 | Samsung SYNC SGH-A707 Cellular Phone
DISK PROBLEM
אתה יודע איך אני עושה ערכות נושא לפלאפון?
Dec 12, 2007 | Sony Ericsson W200i Cellular Phone
Synchronizing Outlook to my T5 but not my T5 to Outlook (without erasing any data on either device)
A possible workaround: I agree that the current synchronising behaviour is not very helpful - especially as it is not very clearly documented - I nearly lost all of my personal calendar data completely! What I have done for now (and this may not be acceptable to you) is to allow Outlook Calendar to synchronise fully with my TE, but then mark all my personal appointments etc. as 'Private' (tick box in lower right hand corner of details). Tedious, I know, but hopefully will get easier as I go along... It is even possible to set up a 'filter' in Outlook so that the personal data is not displayed [Customise View: Filter / Advanced / Field: Sensitivity = Normal] All your personal calendar data on the Tungsten will now be marked as private as well, so if you want to hide any 'really' private records on there, you'll have to set Security to lock the handheld on power-off until you enter a password. Like you, I look forward to Palm resolving this issue by installing 1-way options on their conduits!
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
LG KC550 Triband GSM 5MP Camera MP3 Phone Black Logo
103 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
