Question about RCA P61927 61" Rear Projection Television
RCA 2001 P61927
When I turn our tv on it shuts off by itself or changes channels by itself nonstop. I unplug it from the wall and when I plug it back in it automatically comes on and starts flipping channels again. My husband took the front of the tv off and look at it. Put it back together and it worked but not even 20 minutes later it starting flipping channels again.HELP!!
  • RCA Master
  • 3,866 Answers
Okay there is something wroung with the frount panel there may be debris in where the button is depressed or seomthing is depressing the button or it may be just going out on you.
1. take off the frount cover and examine the channel up and down make sure its clean and there are no debris.
2. if that does not work replace the controller board aroun $65 bucks.
I do not know your zip code but you can give these folks a shot www.teexp.com you can call and ask how much it would cost to replace this controller even though they might not work in your area they still can give you a price.
Thanks
Posted on Jul 17, 2009
Television buttons unit do not work
Try power cycling the TV. To do so, unplug everything from the back of it, power off the TV and unplug it from the wall. Leave it unplugged for a few minutes, and then re-connect and plug the TV back into the wall. Turn it on and reset any system setting changes back to factory defaults. If the problem(s) still exist(s), then I would recommend scheduling repair service.
Oct 05, 2013 | Insignia IS-LCDTV32 32 in. Television
My toshiba 40RV525u flat TV is muted, the tv seems like it controls itself when i go to Menu (selection flashing nonstop). I tried to turn up the volume, but it turned off itself. the entire problem is the...
Do a hard reset to this TV, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Oct 27, 2017 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 32AF44. While watching a baseball game yesterday, the volume bar appeared by itself and scrolled down to zero. The bar will not disappear. It's like someone is holding the down button. Tried...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
Mar 04, 2017 | Toshiba 32AF44 32" TV
RCA TV changes channel and volume, and shuts off by itself.
ok its not a cap problem.. memory ic problem...u have to replace memory ic the nos are i think 24c16 or24c08
u have to buy the memory by giving ur model no of the tv
Mar 06, 2010 | RCA 27V520T 27" TV
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
Samsung 50" DLP TV turns itself off
I had the same problem which also included the picture having streaks of red in it sometimes too. I found that both problems were due to the TV getting too hot inside. I bought a $7 small 4" fan from Walmart and pointed it at the back "door" of the TV (where the bulb can be replaced). Both problems have disappeared which I think is due to not letting the interior get too hot.
Not sure if there is an internal fan to cool the parts inside, but if there is it is not working well enough.
Jun 11, 2009 | Samsung DLP HL-P5663W 56" TV
RCA P52929 changes channel non stop
try unplugging it from the electric wall outlet for an hour then plug back in, this should reset your tv back to factory default, you will have to adjust your setings if you changed them
Jan 25, 2009 | RCA P52929 52" Rear Projection Television
Tv turned off while wathcing, can turn back on but no picture.
This sounds to be a faulty flyback transformer, as it heats it gets a shorted winding and the protection circuit shuts the set down to avoid big sparks.
this is not a user solvable problem unfortunately and i would recommend taking it to an electronics repair shop and getting a quote for repair.
Nov 12, 2007 | RCA TruFlat 27F520T 27" TV
My dvd shows prog 200 and wont change
FIXED! LG DAT-250W INSTRUCTIONS: TURN OFF THE MAINS POWER AT THE WALL UNPLUG ANTENNA FROM THE BACK TURN POWER BACK ON AT THE WALL & START AS NORMAL IT WILL COME UP WITH "POOR SIGNAL" THEN WE FLICKED THROUGH THE CHANNELS & TURNED IT OFF AGAIN AT COMPONENT & AT THE WALL PLUG THE ANTENNA BACK IN TURN EVERYTHING BACK ON Note: **Just avoid the channel that keeps locking up** LG are aware of this issue
Sep 30, 2007 | LG Televison & Video
Help me...
1)pull chassis-solder any/all bad connects. 2)Replace shorted horiz o/p xistor #237470 and IHVT #257805 or Asti 2078
Sep 02, 2007 | RCA F32650 32" TV
RCA P61927 61" Rear Projection Television Logo
269 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
