-   I have Kenmore model 120, which does not fill in water, however, once filled manually it does other functions i.e spinning and emptying.
-   Guest
Nov 25, 2008
-   The washer will not fill with water. When I try to force the water level dial to a different setting the water will start to fill as long as I hold the switch in the middle of two settings. As soon as it is set to a certain level the washer will go through all of the other cycles but without water. -   chad_pcw
Jul 20, 2008
-   Washer does not seem to fill with water. kind of a dry wash!-   jc_woodworks
May 29, 2008
-   NO WATER -   Guest
Apr 19, 2008
-   Water won't fill on cycle 1; other cycles seem to be working.-   ErickBlue
I have a Maytag Neptune washer FAV6800AWW that I had the clutch replaced not long ago. Now it has a...
(More)
I have a Maytag Neptune washer FAV6800AWW that I had the clutch replaced not long ago. Now it has a grinding sound, like a bad bearing or something when in the wash cycle. It seems ok when it spins out and using smaller loads doesn't seem to help. Any ideas? It is very loud, could it be the transmission?
