Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Exact same issue...
If I unplug the drive and then plug it back in (power source) the lights blink and nothing happens.
  • 3,866 Answers
Okay most of these can be fixed when buying another external case! These are SATA drives inside all you need is a case for it take it out of the case and put it into another and you are set again. Most of these drives loose there controller befor the disc so try that I know it will work as it did for me.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jul 17, 2009
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
Power supply in HP slimline s7310n
It sounds like the CPU is over heating. It probably has poor ventilation. Unplug the unit and open the side panel. Carefully vacuum all the dust inside. Be careful not to damage any electronics. You can use a small brush to loosen the dust before vacuuming. Good luck!
Apr 11, 2017 | Computers & Internet
HP 4530s will not power up no matter if the power source is plugged in or with battery. When I push the power button there is nothing happening. I noticed that just above where the power plug in to the...
Try another cord/charger with the EXACT same power specs. Has the cord been pulled while it was plugged into the laptop damaging the AC jack? If you have a multimeter you can verify you are getting the correct DC volts at the laptop ac jack plug. Try HP Support for a explanation of the small led blinking: http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?locale=en_us&taskId=135&prodSeriesId=5060880&prodTypeId=321957
Apr 07, 2013 | HP Computers & Internet
I turned my tv off, but then tried turning it back on and nothing happens. And the red light on the front is blinking. I've tried unplugging the power source and plugging it back in, but the tv won't come...
The tv power supply board is is problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 23, 2010 | Panasonic TCP50C2 50 in. TV
Sony kv36hs500 tv, suddenly no power, no standby lights, no sound
U check the power source?Take the tv aparts,check or replaced the power fuse,might get lucky.Not,than sorry,this tv can't be repair,without replacing electronic's componnents parts.Hire the same shop to do the repair.Ur tv power ICS inverter are dead.
Jun 15, 2010 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My Dell laptop d600 suddenly shut off and will not power back up....led light on adapter blinks when plugged in...I have tried re-inserting RAM modules but this or nothing else seems to work.. thank you...
Unplug your battery and then plug in AC adaptor and see if laptop powers on. I assume you power button doesnt turn on at all? If so, your motherboard seems to have a power issue. Unfortunately, you have to replace motherboard. If laptop. powers on withour battery then you then battery needs replacement.
Nov 25, 2009 | Dell Latitude D600 Notebook
Lights flash on HP deskjet 6127
from what I read on line at HP forums unplugging the network cable may fix it. Others sat they had to buy a new printer
HP DJ 6127 after change of the cartridge blink lights nothing else happens
Jan 29, 2009 | HP DeskJet 6127 InkJet Printer
Power light blinking green,nopicture lc-32sb24u lc-37sb24u
This same thing happened to me, but not until I fiddled with all of my remotes, trying to see if it was an input issue, battery issue, etc. I finally unplugged the tv from the wall and plugged it back in. Nothing. Then I went to take 5 minute ****. When I finished, the Power & OPC lights were blinking, and out of sync. I pressed the power button at the top of my TV and got a picture.
Word.
Dec 31, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
No power, power supply & motherboard green light blinking
I had the same exact problem for the same exact reason. Plug the power cable into the back. Open up the side of the case and unplug all the wires that the power supply plugs into. The motherboard, harddrive, cd & dvd drives, everything. wait about 10 minutes and plug them back in, plugging the BIG cable that connects to the motherboard back in LAST. This will make the light go from blinking to solid. I think it is a safety? to protect the motherboard from damage.
Nov 01, 2007 | Sony VAIO VGC-RB42G PC Desktop
Blank screen, no sound
If ti blinks three times, then it may be an issue with the flyback transformer. It's called "three strikes"...it tries three times to come on, and after that enters a safety shutdown mode to protect the TV. Might need to have a professional shop take a look at it.
May 02, 2007 | Durabrand DWT1905 TV
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
200 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
