How much is a g board for sony kdp51ws655?
G board for sony kdp51ws655 needs to be replaced? how much will it cost and where can i get one?
  • 8,617 Answers
That board has been discontinued by sony. The only option is to have your G board rebuilt. The following link does offer a rebuilding service for most television boards.
Posted on Jul 18, 2009
SONY LED TV MODEL - KDL-40W900A .MOTHER BOARD IS DAMAGED. REPLACEMENT COST 8000-10000 INR. CAN ANY ONE SUGGEST IF REPAIRING MOTHER BOARD IS POSSIBLE?? AND WHERE IN MUMBAI ?ANY CONTACT DETAILS ...
Mother board repairing at component level is not possible to Sony. It is best to replace it. Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 02, 2016 | Sony Televison & Video
I have a Sony Wega 50" Kdp51ws655 and it blinks ten times and shuts on and off. Help plz
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 17, 2015 | Sony Televison & Video
My sony bravia 46" doesnt
hi,
you have to replace the inverter board. If the invereter board overloaded the powers supply, then the tv will go to standby after some time.
ok
Jun 21, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I haqve a sony KDP51ws655. It won't come on , the standby light blinks 10 times
Please check and replace the D6301 & D6109 in D BOARD with the same value.
Thanks
Nov 24, 2009 | Sony KP-61V90 61" Rear Projection...
I have a Sony Trinitron KV-32HS500 that won't turn on. It blinks 7 times. I was told it was a power supply problem. What part do I need to fix this?
The Power Supply/ Deflection Board is called the "D" Board. Replacing this Board should fix your problem. You can try to order one from Sony at 1800-222-SONY. If it is not available, you will need to send it to Sony for them to rebuild it. That will cost around $400.00 or so.
I hope this helps,
Skyassoc
Nov 14, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
No picture,red light after multiple component replacement
Good afternoon! It is possible to change the system, NTSC / PAL-M, the projection TV SONY: KDP51WS655 via SERVICE MODE?, If not possible, could you please tell me if there are any points of video, where I can stop and insert a module transcoding in the circuit.
Aug 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a bravia xdr9 and it has a vertical red line on the left part of the screen. I don't loose the picture.
The LCD Panel is the source of the problem. Sometimes the T-Con Board that connects to the LCD Panel fails causing this problem. For the most part, the Panels come with this Board and the Board is not available by it's self.
In short, the LCD Panel needs to be replaced.
Due to the cost to replace, I recommend you to call Sony at 1800-222-SONY to see if they would be able to help you in the repair cost.
I hope this helps,
Skyassoc
Aug 25, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Sony fb3 boad kdl40v3000 Our tv would not turn on except the flashing standby light. Technician told us we need to replace the fb3 board. The cost is $395 for the board and $185 labor. Is this reasonable?...
This is not a unusual amount for repair. Most repair facilities do not like using used parts on sets they have to warranty after a repair. They would then be liable if were to fail and then they would be replacing it at a greater cost to them. You could check with Sony and see what their retail cost is on the part. Their Customer Service Line is 1800-222-SONY.
I hope this helps,
skyassoc
Jul 24, 2009 | Sony BRAVIA KDL-40V3000 Television
Sony FD Trinitron Wega
The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
Nov 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony wega 51" rear proyection no turn on
Hello had the same prob need to replace DIODES, D6116 and D6301 very cheap to buy on line and then they need to be sotteried on (sp) .
Oct 15, 2007 | Sony Grand WEGA KDP-51WS655 51" Rear...
Televison & Video Logo
222 people viewed this question
Top Televison & Video Experts
