Question about Sub-Zero 19.3 cu. ft. / 547 liter Upright Freezer 601F
Need to replace the ice maker for my subzero 601F
  • Sub-Zero Master
  • 4,654 Answers
Found that ice maker at only one location. Hope this helps, Thanks Sea Breeze
http://www.repairclinic.com/SSPartDetail.aspx?s=t-601F-%3d%3dc248i1266719&PartID=1266719
Posted on Jul 18, 2009
Ice maker is not making ice
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
My subzero 601 F freezer door gets hard to open unless you wait 4 minutes. While investigating this I discovered that there is a buildup of ice in the trough behind the icemaker. It appears that the drain...
switch off machine. open doors an manually defrost.clean any filters/drain holes(wire is not heated,pull/push to clean pipe)dry as best you can.switch on again.it is best to manually defrost any unit every 6 months and if temp edjustable adjust to -20c for optimum economy.water to icemaker is not important on 601f but is on some others.be carefull
Feb 06, 2010 | Freezers
Ice maker does not make ice i replaced filter still no ice
check the fill tube for ice blockage.some times water will freeze in the tube and stop the water flow.also if the unit has a reset button on the ice make reset it a few times.and if tat does not change any thing check the fill valve and water supply line.last thing too do is replace the ice maker
Jan 22, 2010 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Subzero Freezer ice keeps building behind coils
in 601 model. really common problem is the drain hater. watch close the ice maker for a BIG long ice. on the cotton psrt of the back wall. some models have 1 some 2 depends in the serial num. ask you tech for replace the DRAIN TUBE HEATER. that way your cover. really helps a lot the code number...................good luck................. leave a comment...........thanks
Sep 28, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Freezer always on
If the display reads -20 even though the freezer is set for 00, shut the unit off. If you can still hear the freezer compressor running, the board has a stuck relay for the freezer compressor. You will need a new board.
Jan 20, 2008 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Sub-Zero 19.3 cu. ft. / 547 liter Upright Freezer 601F Logo
615 people viewed this question
Top Sub-Zero Freezers Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
AJMAL KHAN
Are you a Sub-Zero Freezer Expert? Answer questions, earn points and help others
