Top removal Need help with how open the top of Kenmore Elite washer to change lid switch.
  • 2 more comments
  • chevylove490 Jul 18, 2009
    What 2 screws in what panel?
    There isn't 2 screws on any any panel.The Model# 110.24942301(Kenmore elite)
  • chevylove490 Jul 26, 2009
    That only works for Whirlpool. I talked to a Whirlpool rep who showed me how to open the top. There are clips under each corner on the control panel.
    By inserting a thin putty knife I was able to push the clip and release the top. Thanks anyway bro.
  • 234 Answers
Peice of cake, my friend :)
Just take the 2 screws off from each side of the panel, then flip it around and pop the gold metal clips out. After that, unplug the connector and remove the entire frame, just like that. Then you can have access to the swich.
The only hard part is putting those gold metal clips back so just watch carefully at how you take them off. Good luck! :)
Posted on Jul 18, 2009
  • Ned Halaweh
    Ned Halaweh Jul 26, 2009
    The screws are either in the front or back of the front panel where you push the buttons.
    1 screw on each corner.
How do i remove the agitator on my kenmore elite washer
See if the top of the adgitator is removable, there is a bolt way down under the liquid fabric softener and top lid. And possibly a top sealed cover as well...
Aug 02, 2014 | Kenmore 4.3 cu. ft. High-Efficiency...
Kenmore elite washer troubleshooting
check the switch that recognizes the lid is closed...may need to open the top of the washer...Ron H
May 26, 2013 | Kenmore Oasis HE 27082 Top Load Washer
We need to replace the lid switch on a Kenmore Elite Washer...how do you do that?
Look on the back side of your control panel.Remove the screws from that panel you will find documents about your Kenmore..
Sep 17, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
My kenmore elite oasis waher is giving me a lid open fault, but the lid is closed. how do i clear this fault?
the lid switch under the lid is bad and doesnt close its contacts even with the lid down,replace it
Aug 22, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
How to open the top of my kenmore elite washer
There are two metal clips under the lid, about 3 inches in from the corners in front. You have to slip a flat screwcriver or a paint knife into the clip and push hard. Once the clip opens you can lift up the top of the washer. If you need to remove the tub, you have to first remove the cap from the top of the agitator. That will reveal a bolt that has to be removed in order to lift the tub out. I hope this helps.
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a Kenmore top load washer (110-22642100) that will fill, agitate through entire wash cycle, but that's it.
HI THERE, IT SOUNDS AS IF YOUR PUMP IS BLOCKED, NOT WORKING OR SOMETHING MORE SERIOUS. START BY CHECKING THE PUMPS IS NOT BLOCKED, LOOSE CHANGE NORMALLY CAUSES THIS AND IS RELATIVELY EASY TO FIX.
Finding the pump on the Kenmore Elite top load washer is a fairly easy project that can be done in about a half hour. The Kenmore Elite is part of the GE line of appliances and shares many of the same interior mechanical parts and systems. The Kenmore Elite is a very streamlined exterior cabinetry design, but the interior can be accessed by removing just a few screws in order for you to locate the water pump.
things you'll need:
  • Screwdriver
    • 1
      Unplug the electrical cord of the Kenmore Elite top load washer from the electrical outlet before attempting to locate the pump.
    • 2
      Remove the end caps on the control console of the dryer by pressing in on the caps with your thumbs and pulling the caps forward to unfasten them.
    • 3
      Unfasten the screws on the ends of the control console in the front with a screwdriver and tilt the console back so that it rests on the back hinges.
    • 4
      Unplug the top lid switch from the rear of the lid that sits underneath the control console, pulling the switch straight up off the metal prongs by hand.
    • 5
      Pry the metal clips that sit on the top lid up with a screwdriver, lifting the clips to unlatch the top and pull the top lid cover off the washer base, setting it aside.
    • 6
      Locate the water pump at the base of the washing machine on the top of the motor shaft.
    • 7
    • take the cover off the pump and remove any blockage or debris.
thanks and good luck
iain
Read more: How to Find the Pump on a Kenmore Elite Top Load Washer ' eHow.com http://www.ehow.com/how_6304872_pump-elite-top-load-washer.html#ixzz1LQ4bdiFZ
May 04, 2011 | Kenmore Washing Machines
Won't start when cover closed
your lid safety switch is shot,you need to remove 2 side control panel covers that pop off,then remove 2 screws that are under here, then control panel will separate from top to let you unplug lid switch connection to the control panel,then open the top cover by popping clips inward on the 2 front corners with a putty knife or something flat like this between the top and front covers,then raise top up and lean back against the wall there you can access this switch to replace it,this switch is designed to shut off unit if lid is raised during spin cycle for your safety
Dec 11, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
I have a top load Kenmore Elite Washing machine that runs for 5 seconds then stops for several minutes. This pattern repeats. It just started yesterday. What is wrong with it? I have unplugged and...
Sounds like the timer is faulty. Or you lid switch is out of wack. Try leaving leaving lid open and placing a screwdriver in switch located where the lid clip comes down into washer. If this works the switch will need replaced. Timer is another story as you will have to remove top panel and replace timer if the lid switch is not the cause
Mar 23, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing Machines Logo
247 people viewed this question
Top Washing Machines Experts
