Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
I was trying to protect some pictures and now I have locked the memory card. How do I get it unlocked and the pictures unprotected so I can erase them?
  • Canon Master
  • 19,396 Answers
You cannot lock the SD card from menu, if the card reselt protected it can be damaged, the first thing to do is download the pictures to computer. Protected pitures can be downloaded normally.
If you instead need to remove protection from pictures, this must be done acting on the pictures one by one.
To remove protection go to play meny , select the function Lock, then press Funct/Set button twice to remove protection.
If that does not work take out the SD memory card and check that the tiny tab on one side of the card had not been set to lock position.
If card is still locked, take out the card, put in a computer with card reader , and format the SD card.
Remove camera batteries for one minute, so to reset settings, then put the newly formatted card back into the camera.
Manual available here.
Regards
Posted on Jul 17, 2009
My fujifilm finepix jx 300 says protect card even after sliding the switch on memory card to unlock
check if in the card slot is any debris. You could try to clean the contacts of the xD memory card with a dry cloth. Place the card on a flat underground and press firmly on the cloth. Don't press without a flat underground, because you could easy break the card.
It also could be some of your pictures are protected. You have to unprotect the pictures first.
Nov 15, 2013 | Fuji FinePix A303 Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
My camera won;t let me take pictures because it says its "write protected"
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 14, 2011 | Nikon COOLPIX S10 Digital Camera
My camera says that the memory card is protected. I cannot unprotect it. Any suggestions? I cannot take pictures or erase pictures, only view them.
First, make sure the slide switch on the side of the card is in the unlocked position. Then press "menu/set", playback menu, select "protect" and then choose cancel.
Oct 16, 2010 | Panasonic Lumix DMC-FX8 Digital Camera
The camera says that my Memory card is protected. How do I unprotect my pictures? Also how do I reset switch on memory card? Thanks
If you had protected any pictures on the card, then while viewing that picture press the Menu button. Use up/down to select Unprotect.
Oct 13, 2010 | Kodak Easyshare C182 12MP Digital Camera
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
I cannot erase video I took on envy2. When I
if you are using a memory card, your card may have a swich on it that locks and unlocks it
Jun 17, 2009 | LG enV VX9900 Cellular Phone
Locked Card
Change the memory card lock switch to the normal setting84b4934.jpg3c6d94b.jpg
Good luck....
Nov 18, 2008 | Canon PowerShot S51S Digital Camera
How to unprotect the memory card
If I understand correctly what your asking what is the brand and size of the memory card. If I were to take a stab at it right now I would assume there is a lock/unlock switch on the card. Have you had this problem with the card before?
Good luck,
Lee
Jun 13, 2008 | Polaroid I533P Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
65 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
