Cars & Trucks Logo
m
matthew scott Posted on Jul 01, 2016
Farmall tractor how do I replace the front oil seal on transmission drive shaft of farmall md
2answers
Transmission rear seal instalation
remove the drive shaft ( tail shaft) lever out the old seal. put sealer around new seal and fit back in extension housing. Use something that is the same size as the outer edge of the seal and tap it in flush with the edge of the transmission housing. Expect some oil to drain out when the tail shaft and seal is removed
What would make a trans squeal while driving down the road?
You don't say, Front or rear wheel drive. First check oil level, On rear wheel drive check the thrower plate on the tail shaft at the diff end is not bent and rubbing on the seal, A dry oil seal can make this noise.so can the U/Joints. on front wheel drive , check the cv joints , dry oil seals , the drive shaft inner cv joints have a thrower plate that may be bent. worn or binding brakes can make this noise also.
Oil leak at transmission shaft
you newed to pull the rear u bolts and take th drive shaft off then you can replace the seal its realy not hard
1996 chevrolet impala ss oil leak rear of engine
Is it engine oil or transmission fluid? Is it driven often or does it sit in the garage? If engine oil, then possibly the rear seal is leaking into the bellhousing as you drive and then draining on the floor after you stop. If ****** fluid, then possibly front seal on ****** is leaking. If car sits for long periods of time the input shaft seal can allow fluid to leak past the shaft. This usually will fix itself when driven. Can't promise it will fix itself permanently. Will not be an easy fix if either seal needs replacing (or cheap).
Need to replace oil pan on a bmw 2004 330ci
Raise engine with special tool 00 0 200 approx. 5 mm.
- Remove suction filter housing. Remove engine splash guard.
- Drain engine oil. On vehicles with automatic transmission:
- Disconnect oil lines from automatic transmission and from oil pan.
- Release guide tube for dipstick.
Note: M52TU and M54 only.
- Detach return hose from cyclone oil separator on oil dipstick guide tube.
- Replace O-ring.
- Remove front end reinforcement.
- Detach steeling spindle from steering gear.
- Remove vane pump for power steering unit (lines remain connected).
- Disconnect plug connection to oil level sensor.
- Loosen top and unfasten bottom of left and right engine mounts.
E46 4WD only
- Remove left and right swivel bearings.
- Remove output shafts. Remove front propeller shaft.
- Remove front axle differential.
- Detach brackets for left and right control arms from engine carrier.
- Release retaining brackets for left and right stabilizer bars.
- Unfasten screw connection on front axle support and lower the front axle support.
Note: There is no need to detach the steering gear from the front axle support.
- Unfasten oil sump screws at transmission and engine ends.
- Lower and remove oil sump.
Sealing faces clean and free of seal debris.
Apply approx.3 mm wide, 2 mm high coat of Drei Bond 1209 sealing agent to the area around seams.
Installation:
  1. Replace gasket
  2. Install oil sump.
  3. Insert all oil sump screws.
  4. Insert screws in transmission end without preload at this stage.
  5. Tighten down screws in engine end.
  6. Tighten down screws in transmission end.
E60 Removing And Installing, Sealing Or Replacing Oil Sump (M54)
Necessary preliminary tasks. -
- Remove intake filter housing
- Remove guide tube for oil dipstick
- Lowering front axle support
- Drain off engine oil
- Detach oil lines from automatic transmission and from oil pan.
- Unfasten oil pan screws at transmission and engine ends.
- Lower and remove oil pan.
Installation:
Apply approx.3 mm wide, 2 mm high coat of Drei Bond 1209 sealing agen to the area around seams.
Installation:
  1. Replace seal.
  3. Insert all screws on transmission end, without preload at this stage.
  1. Tighten down screws on engine end.
  2. Tighten screws on transmission end.
Or take it to a dealer....
1helpful
2answers
I have a 2000 beetle turbo and just notices it is leaking oil from around the plug which is tight and seeping transmission fluid. Is this going to be a costly fix?
OIL LEAK AROUND THE SPARKS PLUGS COULD BE LEAKING VALVE COVER GASKETS ALLOWING OIL TO SEEP BY GASKET FLOW DOWN AROUND SPARK PLUGS.TRANSMISSION LEAK IS NOT VERY EXPENSIVE LONG AS TORQUE CONVERTER SHAFT SEAL NOT LEAKING WHICH TRANSMISSION HAS TO DROPPED OUT TO REPLACE SHAFT SEAL.IF TRANSMISSION LEAK AROUND FRONT AXLE SEAL IT MAY COST A LITTLE.BUT PAN GASKET LEAK OR OIL COOLER LINES WONT COST TOO MUCH NOT HARD TO GET TO REPAIR.PHONE AROUND GET PRICE CHECKS.
What would be a reasonable price for the following work and how would I know if these things were actually done? 2003 Audi A6 Transmission filter kit Water pump Timing belt Idler pulley Rear...
it is VERY unlikely that a seven year old car would need that much done to it, unless it had 200,000 or more miles on it. New oil should be the color of honey, not dark brown. That's the easy check.
If there is a transmission fluid leak in my 2004 Monte Carlo, what would be the likely cause(s)?
hi there is 2 possibilities on this one, first the front oil seal that is on the input shaft that goes into the engine/motor, then there is the oil seals that are on the drive shafts where they pushe into the transmission, and this realy are the main ones...hope this helps
3helpful
Automatic transmission leaks on my 2000 Rodeo 4wheel drive Any help? Please
If you have never serviced the transmission, it just may be time to have the transmission fluid and filter to be replaced if the transmission fluid is leaking from the transmission pan. If it's leaking from the rear of the transmission where the drive shaft goes in to, then it's the rear seal from the transfer case and the seal needs to be replaced and the transfer case topped off with fluid. If the fluid is leaking from the front of the transmission where the engine connects to the transmission than it's a good chance that it's the torque converter or front pump main seal. The other place that it could be leaking from is the transmission oil lines from the transmission to the cool at the radiator. Please let me know if it's leaks worst when the engine is running or only when your parked for a few hours. Keep me posted, be glad to help.
Our 2001 Dodge Caravan seems to be leaking oil around drive shaft
Yes it's a bad seal and most likely the side bearing to the trans axle is bad too. Once the bearing has play, it vibrates and causes the oil to leak though the seal. Note: if one side went bad the other side is soon to follow since they have the same amount of miles on them. Might as well change both side. Good luck and hope this helps. Keep an eye on the transmission fluid level, don't want to burn out the transmission.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
