Question about Kenmore Dryers
90 series dryer will not run. The heater turns on even if the door is open and have not pushed the start button.
    President:
  • 744 Answers
Hello again your not testing the heater correctly, I saw your pictures and you need to remove the wires off the terminal before testing, your reading condinuity off the cuircuit. remove the wires now test each terminal against the heater casing if you have condinuity the problem is as i said broken coil touching the chassis. you also need to remove the heater and visually inspect it carefully..you will find a break. testing switch on motor and stats a waste of time..cannot cause this. please test the heater correctly this will be your problem!!!
Posted on Jul 19, 2009
    Genius:
  • 1,122 Answers
Does the drum turn at all?sounds like you have a dead short on the heating element,remove front and bottom panel and check it-mike
My series 90 will only Run if i holding the Starter but ton
I would start by checking the centrifugal switch on the motor.
When you push the start button, the motor starts turning, then the centrifugal switch on the motor clicks in and keeps the motor running until the timer or the door switch cuts power to it. If the centrifugal switch isn't working, the motor won't stay running.
Good luck
Oct 27, 2014 | Kenmore Dryers
Kenmore 90 series heavy duty model 67902, when I push the start button the motor turns on briefly but when I let go of start button it stops.
http://fixitnow.com/wp/2009/03/17/easy-fixes-for-two-common-problems-with-the-whirlpool-even-heat-dryers/
Nov 27, 2010 | Kenmore Dryers
I have a Kenmore 90 series gas dryer Model# 7691269076912 When I push the start button it whines then nothin. I used wait a few minutes and just start running. now you push the start button, it whines then...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 20, 2010 | Kenmore 77632 Gas Dryer
Kenmore electric dryer series 70 makes loud buzzing noice
Sounds like you have a motor problem draging and it can't get started I just replaced one same problem.
Apr 24, 2010 | Kenmore 63942 Dryer
Dryer doesn't always start, and doesn't keep running
your have a dieing dryer motor,weak weak to turn the drum anymore,the model number is inside the dryer door if you want to try and find one cheap on ebay-mike
Feb 23, 2010 | Kenmore Dryers
My kenmore 90 series dryer's push start is in operative how can i repair this problem
It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Aug 02, 2009 | Kenmore 75944 Gas Dryer
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
