Question about Kenmore 24032\24036 Top Load Washer
Leaking oil I just changed the motor coupling on my Kenmore 60 series washing machine and now it is leaking oil from the coupling area.
  • 6,784 Answers
The transmission or, gear box housing is compromised. it has cracked for some reason. you will need to replace the transmission in this case.
Posted on Jul 17, 2009
Kenmore washer 90 series transmission - does it need replaced?
oil leaking is a good indication not to use the transmission
Apr 16, 2012 | Kenmore Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore Series 80 Washer leaking oil underneath
TRY TO CHECK THE RUNNING CAPACITOR MAY BE THE OIL THAT YOU SAW CAME FROM THE DAMAGE CAPACTIOR.
Aug 21, 2009 | Kenmore 22642 Top Load Washer
Kenmore washing machine series 90 is leaking
Tip the washer onto the front and you will be able to see through the bottom to look for leaks.
May 31, 2009 | Washing Machines
Spots on my clothes after washing.
the transmission seal may be going out leaking oil
Apr 24, 2009 | Kenmore Washing Machines
Hi MPT,
Don't take the back panel off!!!
Watch this video to learn how to access the machine.
Generally on a Whirlpool built Kenmore like yours, the drain pump has failed and now it's leaking. The pump is right there in front, the big round white thing. It's connected to the motor by 2 clips. It'll be one of two types of pump... this one or this one <----notice the difference in hose connections?
It's easy to replace, just make sure that the machine is completely empty when you remove the hose or have a shop-vac handy when you do.
And don't forget to rate my solution as "FixYa", deal?
SG
Apr 17, 2009 | Kenmore Washing Machines
Tub won't agitate and when it does spin, makes a grinding noise.
its probably in the gear case. or spin tube bearings. did you see any oil leaks on the gear case or clutch and break area.
Feb 07, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Series 90 won't spin
AS LONG AS THE MOTOR RUNS, I WOULD CHECK THE CLUTCH RIGHT UNDER THE TUB TO SEE IF OIL HAS LEAKED INTO THE PADS CAUSING IT TO SLIP. IF NO OIL OR EXCESSIVE PAD DUST INDICATING WEAR, IT MAY BE A PROBLEM IN THE TRANSMISSION.
Jan 27, 2009 | Kenmore 22422 Top Load Washer
KENMORE SERIES 80 WASHER
There is three things on this machine that concern me. Last week I rebuilt a series 80 and it did the same thing, mostly on perm press. It turned out the timer was fine and the mechanical had not been rebuilt in years. Because of this the motor could not spin fast enough to fling the water plus the pump was leaking. I need three things from you. Is leaking water and oil when looking under the machine, does the motor hum loud even when functioning normally and when its spinning lift the lid, is it still rotating after a quick count to 7? Drop me a line I would like to help.
Sears Tech Too
Sep 07, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
259 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
