Question about Nokia 2310 Cellular Phone
It on test mode and can not display - Nokia 2310 Cellular Phone
How do I run diagnostics on a Frigidaire Gallery Refrigerator
Ice Maker (Flex Tray Fresh Food Compartment)
The Ice Maker must be turned on before entering the
Service Mode. Check the 'ice off' indicator on the User
Interface to verify that the ice maker is in on.
Diagnostic Service Mode Activation
Express-Select ™
To activate the Ice Maker Service Diagnostic Mode,
press and hold fresh food and freezer up (?)
simultaneously for up to ten (10) seconds.
Pro-Select ™
To activate the Ice Maker Service Diagnostic Mode, press
and hold 'options' and 'power on-off' simultaneously for
Activation of Ice Maker Service Diagnostic Mode
automatically turns off all Ice Maker Control PCBA
outputs. The compressor runs at fixed speed of 4500
rpm and the condenser fan turns on until Service Mode
is deactivated. The damper is closed and the fresh food
and freezer lights are enabled as well as the alarm audio.
Defrost of the main system is not allowed.
Deactivation
Express-Select ™
To exit service mode, press and hold fresh food (?) for
up to 10 seconds.
Pro-Select ™
To exit service mode, press and hold the (+) key for up
to 10 seconds.
Service mode is also automatically deactivated after 5
minutes of no key entries (that includes Communication
Lost). All outputs are turned Off. Previously selected
main system and ice maker operational modes are
restored.
Testing
To actuate an ice maker load of the selected test step
(turn on or off), use 'power on-off' on the user interface.
To step to the next ice maker sequential test, press fresh
food (?) or '+' on the LCD screen. To step back to the
previous ice maker sequential test, press fresh food (?)
or '-' on the LCD screen. The selected test number will
be displayed on the fresh food display.
After pushing 'power on-off' to start automatic test
or turn on the load, the ice maker control will display
the test result on the freezer two digit display. When
waiting for the test to be automatically performed and
the result displayed, the test number (test ID) will flash
on/off. After the automatic test is completed the test
result will be displayed as "P" - pass, or "F" - Fail.
For an interactive test, the technician manually activates
the load using 'power on-off' and physically verifies the
system response. Pressing 'power on-off' again turns
the load off. The freezer display shows the current or
expected state of the load. During the load transition
the fresh food display flashes the test ID. After the last
test step in the ice maker test sequence is completed,
the next advancing action will scroll back around to the
first ice maker test. Stepping back from the first test, will
scroll the test sequence backwards to the last test in the
sequence.
Note: The only test that the test number will flash during
the test is the bail arm test.
Note: If you advance to another test before the present
test is completed the ice maker will continue to run until
the tray reaches the home position before the next test
will start.
Service Diagnostic Mode Test
Sequence
Test 52C: Ice maker Thermistor Test.
The current Thermistor temperature is displayed on
Freezer display when the test is started. It will show the
temperature at the ice maker if the thermistor is good.
A "OP" will be displayed for open and "SH" for in short
circuit condition of the ice maker thermistor.
Test 55C: Water Valve Test
NOTE: Prior to initiating this test, verify that the ice tray
is empty. If not, empty the ice tray to prevent water
from overflowing into the ice bucket. To empty the ice
tray, remove the ice bin, place catch pan under the ice
tray and initiate test 63C. The tray will twist and empty.
Touch 'power on-off' to start the test. The lower control
board will turn on the green and brown water solenoid
valves for a duration of 4.6 seconds if set for small cubes,
5.8 seconds if set for medium cubes or 7.0 seconds if set
for large cubes. Additional 'power on-off' activations are
ignored. If you want to re-run the test you will need to
advance to another test and then go back after you drain
the water out of th
Jan 16, 2017 | Refrigerators
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Ge front load error codes t01
make this test: God bless you
- 45 -
Service Test Mode
The dryer control has a service test mode that can be utilized by the service technician in order to test
critical components and to access error codes. This test mode will help the service technician to quickly
identify failed or improperly operating dryer components.
Test Mode Description
t01 Model ID Verifi
es (or sets on new board) the proper model id.
t02 Error Codes Lists up to 10 control-detected problems.
t03 Software ID
Displays the software version number and the non-
volatile memory version number.
t04 Program Non-volatile Memory Test Control computes and compares the 16-bit CRC of
the non-volatile memory with the pre-computed
version stored in the non-volatile memory.
t05 User Interface Control turns on all LEDs and the 7-segment display.
t06 Keys Continuity Verifi
es that all displays and buttons work.
t07 Outlet Thermistor Displays outlet thermistor temperature.
t08 Inlet Thermistor Displays inlet thermistor temperature.
t09 Moisture Sensor Displays voltage read from the moisture sensor.
t10 Exhaust Detection Verifi
es status of the exhaust system.
To enter the test mode: To exit the test mode:
Disconnect the power for 30 seconds.
Reconnect power and within 30 seconds of
reconnecting power:
Press signal button.
Press delay start button.
Press delay start button. (Displays t01)
1.
2.
a.
b.
c.
d.
Press the power button during the test selection
mode.
Note:
A dryer left in the test mode will exit the test
mode after a period of 30 minutes
Oct 01, 2013 | GE Dryers
No display
1) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time and hold for 3 seconds. The refrigerator will enter Test Mode 1. Test Mode 1 allows diagnostic function of the compressor and freezer fan, stepping damper open, defrosting heater off and display LEDs all on.
2) Touch the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 1 and hold for 3 seconds. The refrigerator will enter Test Mode 2. Test Mode 2 allows diagnostic operation of the compressor and freezer fan, stepping damper close and defrosting heater off.
3) Press the "Express Freezing" key as well as the "Colder" key of the Freezer Temp function together while in Test Mode 2 and hold for 3 seconds. The refrigerator will go into Test Mode 3. Test Mode 3 allows diagnostic operation on the compressor and freezer fan off, stepping damper close and defrosting heater on.
4) Press the "Express Freezing" key and the "Colder" key of the Freezer Temp function at the same time while in Test Mode 3 and maintain for 3 seconds. The refrigerator will reset to the state prior to entering test mode.
5) Unplug the blog798088-troubleshooting-lg-refrigerator-defrost-cycles.htm&opts=1,3,5Lg refrigerator from the wall outlet, then plug it back in to reset the appliance after coming out of test mode.
Oct 19, 2012 | LG LFX25961SB (247 cu ft) Side by Side...
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
Jun 30, 2012 | Computers & Internet
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
Switches to "Quick Start" before I enter all information
The Maintenance Mode allows you to query and modify the basic settings of the Star Trac Pro
Stepper.
Engaging Maintenance Mode
Press and hold the0 , 2and OK keys together.
A beep will sound and the “MAINTENANCE MODE” will display momentarily in the information
window.
Release all keys. “SERIAL NO XXXXX” will display in the information window.
Modifying the Maintenance Mode
The following keys are used to modify Maintenance Settings:
Upper and Lower Data Information Window SCROLL keys: Display the next and
previous settings.
Increase and Decrease Level Keys: Adjust the value of the displayed
setting up and down respectively, in increments of 1 unit.
OK Key: Updates (saves) the value of the display setting in the Flash memory, and exits
Maintenance Mode.
The Keypad Test can be used to verify that all keys are functioning on the display assembly.
To engage the Keypad Test
Enter the Maintenance Mode (see Settings – Maintenance Mode).
Press until Keypad Test is displayed in the information window.
Press to enter the Keypad Test.
Press each key on the display. Each time you press a key, the information window will display
which key has been pressed.
To exit the keypad test, press .
If any of the keys do not respond, they may not be functioning and the display keypad must be
replaced.
Jan 23, 2010 | Startrac Fitness Products Sc4130 Star Trac...
Stereo not working, and slidind doors either. need fuse diagram
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Digital audio compact disc changer
  • Antenna and two-piece antenna cable or electric antenna
  • Radio speakers mounting/speaker cones
  • Capacitive suppression bond wire and radio receiver hood bonding strap
  • Central junction box (CJB) fuse:
    • 6 (15A)
    • 2 (25A)
  • Ignition switch
  • Circuitry
  • Audio unit
  • Video system
Audio Unit Self-Diagnostic Mode
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, depress the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the ignition switch or the audio unit off.
  1. If the concern remains and the fault is not detected, proceed to the Symptom Chart to continue diagnostics.
  1. The audio unit self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. This test is an on-demand self-test. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. If the system is OK, SELF PASS will be displayed.
    • Preset button 2 = View/clear continuous DTCs. NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > to view the DTCs retrieved. Refer to the audio unit Diagnostic Trouble Code (DTC) Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • NOTE: Always DOCUMENT, CLEAR and CARRY OUT the audio unit on-demand self-test again.
      Preset button 4 = Software configuration level. This test queries each audio unit system controller for its software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    • Preset button 5 = DISPLAY TEST. This test will light all the audio unit display segments for five seconds. When the test is complete, DISPLAY TEST is displayed on the bezel.
May 25, 2009 | 2002 Ford Windstar Cargo
Internal diagnostic mode
To enter Test Selection mode from Customer mode and display the Test Selection screen:
  1. Select Information -> Troubleshooting -> Service Tools from the Control Panel.
  2. Scroll down to Enter Diagnostics and press the OK button.
When the system transitions from Customer mode into Test Selection mode, the initial Control Panel display is the Test Selection screen as follows
Dec 31, 2007 | Xerox Phaser 8500/DN Printer
Nokia 2310 Cellular Phone Logo
75 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
