Question about Carrier 52PQ307 Wall/Window Air Conditioner
Panasonic air con unit is not blowing cold air out.
My Panasonic wall mounted air conditioning unit is not blowing out very cold air.I have cleaned the 2 filters. Could the problem be the outside wall mounted inverter?
  • Anonymous Mar 19, 2014
    I do not know how to change air filter
  • 30 Answers
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Posted on Jul 18, 2009
I have a panasonic inverter air con. Model CU-E18LKR. it's not cooling properly. Seems to be blowing cold air out on th outside rather than inside.need instructions on troubleshooting
This is a reverse cycle (heating and cooling) model. It sounds like you have it in heating mode. Check the Panasonic website for an owners manual.
Jan 30, 2017 | Panasonic Heating & Cooling
How do i stop the leak on my panasonic air conditioner
You need to blow out the drain hose, it's clogged. You can use a water hose to flush out the line.
Sep 19, 2014 | Panasonic CS-MKE12NKU Mini Split Wall...
HOW DO I CHECK AND CORRECT THE FREON LEVEL FOR MY SANYO KS1271 A/C; WHICH IS NOT BLOWING COLD AIR?
Hire a tech it will be cheaper and safer. You may have a capacitor that is bad and not starting the compressor.
Aug 22, 2014 | Sanyo KS1271 11,900 BTU Ductless...
Airconditioner blowing not cold
Yes. its the run capacitor that is bad. as far as the filter, evaporator and condenser coil is clean and compressor is okay as you said. get the exact type and model of the capacitor and replace... let me know... all the best.
Jan 30, 2014 | Panasonic Heating & Cooling
Power light blinking And no cold air coming out
most units have a diagnostic plate on door or manual that will tell you what blinks mean. steady blink is normal on some units.
Jan 20, 2014 | Heating & Cooling
Panasonic cs-w9dk air condition problem
If this is an old unit then you must check the filters, the voltage to the compressor units. If the motor capasitor is weak then the compressor might shut off due to strain and high current drain.
Try and clean , blow air jet into the condenser and also clean or replace the filter and the evaporator. In short the unit needs a check on the gas pumping, if there is shortage of gas and also if there is fault in the power.
Dec 30, 2011 | Panasonic Heating & Cooling
A/c unit just blows cool air not cold air at the high range
mcdevito75 here, have your local a/c shop check it out they come to the house. You can check to make sure you have the unit on cool and that the filter is clean. Unit could use serviceing if not done in 2 years, specific cleaning and a charge of freon gas.
Jun 22, 2010 | Panasonic CW-C141NU Air Conditioner
Good after noon i have a Starway Split Wall Mount Reverse Cycle Air Con. the problem i have is when i need to warm my house the air coming from the system is cold. even with the temp setting on the sun...
Examine the condenser. The condenser pushes the air and expels the warm air from the air condition to the house. Also check the fan heater on your system to see if it is functioning, because if it is not, it will circulate the heat from the unit to the house, in this case,it will need to be fixed. also check if the thermostat on the unit is regulating because if it is not regulating, you will not get the house to warm due to bad thermostat, check to ensure it is regulating, if not, replace it, it might be defected because that is the key to regulate the unit. so pay attention to it to see if it regulating the unit, if not, replace as advice.
Take care.
Jun 12, 2010 | Heating & Cooling
White 'dandruff like' flakes blowing from front & back of air con
this stuff is mold and mildew that builds up in the blower and evaporator section of your unit the unit needs to be cleaned out i'm not familar with this particular brand so I cant tell you how to pull it apart but since it is a split system this means the freon lines will most likely have to be pulled loose. you may try removing the covers and vacuming the unit as well as you can and possibly blowing it out with compressed air. aside from that I would recomend alling a qualified service comapny. good luck peyton
Jan 30, 2009 | Maytag MBB1956GES Bottom Freezer...
Panasonic casette air conditioner-display error temp 'CHECK'
Check that your water pump is working and not blocked up as the unit will keep swicthing off if it can not get rid of the water.
Nov 24, 2008 | Panasonic CW-C60RU Air Conditioner
Carrier 52PQ307 Wall/Window Air Conditioner Logo
1,435 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
