SOURCE: directions on stacking dryer on washer
get a stacking kit from your local appliance strore that sells frigidaire. they ARE EASY TO STACK WITH THE KIT.
SOURCE: Frigidaire Gallery Series Model # GLEH1642DS1 woint spin or agitate
CHECK LID SWITCH. DOES THE WATER DRAIN FROM UNIT
SOURCE: Washer does not agitate
hi thanks for the question it looks like a problem with the transmission but only if afer the water fills the tub the motor starts running if te motor docent start after its full look for a timer problem . so if motor runs on wash cycle and no spin transmission problem thanks the appliance doc please rate me.
SOURCE: Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Good Afternoon Sarah, thanks for your post!
From the information you have provided the washer on your Frigidaire laundry center will not agitate or spin and will drain. This sounds like a possible issue with your motor or belt. In order to pinpoint the issue with your washer you may need to disassemble the washer and test each component for electrical issues and cosmetic damage. This is not a simple DIY job and I would recommend you speak with a professional technician for proper diagnosis and repair. Hopefully this information is helpful. -Matt
