Question about JVC MX-GB5 CD Shelf System
Left subwoofer not working.
The subwoofer on the left speaker is not working.
  • 90 Answers
The wire that runs to the sub woofer.take a AAA 1.5 battery and touch it together if you here nothing speaker.
if you here then its the player.
Posted on Jul 31, 2009
Very week sound
Definitely need more info - such as type of amplifier or receiver, how many speakers you are running, whether the subwoofer is powered or not.
As a simple test procedure: Disconnect all speakers and plug in a pair of headphones. Get a strong audio signal? Good, move on. No signal or week signal, you have an amplifier issue before the audio even gets to the speakers.
Next: Disconnect all speakers, turn the volume down, and connect one speaker to the left output channel. Slowly increase the volume. If that works, do the same on the right channel. Everything OK? You're putting out enough gain on both channels. Sometimes one channel goes bad. You can still listen to your sound in mono moder, or drive two speakers from the single working output. Not stereo, but dual mono. Move on.
Connect left and right speakers but not the subwoofer. Repeat the test. Whatever is left is probably the problem. If the subwoofer is powered, check the power supply or incoming voltage. If the other speakers are driven off the subwoofer or powered from there, that's likely the problem.
Jul 31, 2015 | Audio Players & Recorders
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
Here's my delema...........I have a Pioneer subwoofer HTP102-SW and want to conect to my Pioneer AC receiver. Subwoofer has 8 speaker ports (L+R output & L+R input). Do the speakers connect to the...
The left and right outputs from the receiver go to the left and right inputs on the subwoofer and then you wire the left and right speakers to the left and right outputs on the subwoofer....it is sort of what we calll daisy chained
Dec 30, 2010 | Pioneer Televison & Video
The subwoofer isnt working but speakers are
You mean the right and left satellite speakers are working but the subwoofer is not. Try to adjust the bass control of the subwoofer at the back. Set it to full.
Dec 23, 2009 | Boston Acoustics BA745 Computer Speakers
Left Channel does not work. Subwoofer and Right Channel work fine. The plug needs to be plugged into the brown jack on the front of the computer to work at all.
Sort of sounds like there's a PC in the mix.
Can you swap the left and right speakers to isolate the speaker from the source as the problem?
Have you tried switching the various plugs around to isolate if anything comes out to the Left Channel, ever or if any other speaker plugged in as the Left works at all? Turn the volume down and bring it up slowly at first because if you send Subwoofer programming to a speaker not designed for it you may damage it.
If nothing works when plugged in as the Left speaker, maybe the sound card is the problem. Resubmit a question with the source or the PC as the problem
Nov 28, 2009 | Altec Lansing VS4121 Speaker
HOW DO I PLUG UP THE SUBWOOFER TO AMPLIFIER
On the back of the amp, there should be a jack with the name "SUBWOOFER PRE OUT". It is a standard RCA jack, but it only puts out a line output, meaning only self-powered subwoofers will work with it. Usually, if the subwoofer does not have an amp, it will have 2 imputs and 2 outputs. You plug the two left and right inputs into the front speaker jack on the amp, and then plug the front speakers into the left and right amp on the subwoofer.
Jun 17, 2009 | Audio Players & Recorders
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
Center, and rear surround speakers
Sounds like the rear volume is just turned down. Cant be the amp if the front and subs are working
Aug 28, 2008 | Bose Acoustimass 15 System
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
JVC MX-GB5 CD Shelf System Logo
75 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
