Question about JVC HD-56G787 Television
My television needs a lamp - JVC HD-56G787 Television
  • JVC Master
  • 5,138 Answers
Go to E-Bay to order Lamp 82.00
Posted on Jul 17, 2009
Do I need to order the housing with the lamp after burn-out?
you can order just the bulb then install that in your housing. Being careful not to touch the new bulb with your bare hands as the oils from your finger tips will cause the lamp to fail prematurely.
Feb 07, 2012 | Mitsubishi WD-60735 Projection Television
I have a mitsubishi 73735 television that is not showing a pcture there is a red lamp light on; on the front of the television does the lamp need changing
Hello, welcome to Fixya!
My question would be; how long have you been using the TV and have you every changed the lamp?
If you have never changed the lamp or if it has been a long time since you changed the lamp, then it means the lamp needs to be changed.
The red lamp staying on, also could mean a power problem. But,in any case, go ahead and change the lamp. Hopefully, it should fix the problem.
Regards.
Nov 03, 2011 | Mitsubishi WD-73735 Television
Mitsubishi wd-60735 no picture and red lamp light stays on
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Oct 07, 2011 | Mitsubishi WD-60735 Projection Television
Tv clicks butb wont turn on
If Your television clicks and the bulb wont turn on, then it means the lamp of the television is bad and need to be replaced. The clicking sound is caused by the power reaching the unit but being unable to be used up by the television. You need to replace the lamp to be able to use Your television. To replace the lamp, You will be needing these instruments, a cup, screw driver, replacement bulb and a hand glove. Then You follow the steps below:
  1. Power off the television,
  2. Unplug it from the power outlet and allow the television rest for about 6 hours so the high voltage on it will dissipate as television is well known to store high current after being plugged from a power outlet,
  3. Then You Wear Your hand glove to avoid some sort of shock,
  4. Then You unscrew the lamps compartment and put the screws into the cup in order for You not to misplace them,
  5. Then you turn off the lamps switch that is by the side of the lamp,
  6. Unscrew the screw that is holding the lamp to place,
  7. Carefully pull out the lamp from its casing and replace it with a new one,
  8. Reverse the whole process to reassemble the television back together and remember to turn on the lamps switch,
  9. Plug Your television and power it on.
Hope this was helpful. Thank You for using FixYa!!!
Jan 16, 2011 | LG 42LC2D 42 in. LCD HDTV
WD-62827 62 in. HDTV Television: mY LAMP WENT OUT ND NEEDS TO BE REPLACED, IS THIS ...
yeah ive had this tv for 4 years replaced lamp when i got it then about a year ago there was a but power surge that ruined 2 pc monitors and that lamp just google WD-62827 replacement lamp pick a place to buy from the only tool you'll need is a phillips screwdriver
May 17, 2010 | Mitsubishi WD-62827 62" Television
Lost the lamp cover, changed light and tv wont come on
the lamp cover has a small tab that pushes the lamp switch..the tv will not turn on without..you need it :))
Dec 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony projection television lamp replacement...
hello the last light at the bottom of the tv will flash this will tell you the lamp as burn't out i would buy the lamp in the housing it just makes it easyier to install when you do install it make sure
Nov 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony 42'' kdf42we655 no picture , lamp light flashing
If the lamp light is flashing, yes you need a new lamp. Be sure to buy an original Sony lamp as the replacement lamps are garbage and are not worth the discount. Please rate this solution. Thanks!
Nov 15, 2008 | Sony KDF-42WE655 Television
Need to change lamp
I need to change lamp for sony KF-50we610 TV. Just got the new lamp and ready to change.
Thanks.
Aug 09, 2008 | Sony Grand WEGA KF-50WE620 Television
JVC HD-56G787 Television Logo
106 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
