Question about OfficeMax 0M96431 Shredder
EMBASSY TS 60 ---- PAPER JAM HOW DO YOU UNJAM AND GET THE LITTLE PIECES OF PAPER OUT
Thought this was a helpful and free service from the manufacturer --- thanks -- but I'll figure it out myself -- remove my e-mail address from your list -------
Posted on Jul 18, 2009
This site seems pretty useless...
Posted on Sep 12, 2010
2 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: UNJAM MY EMBASSY TS 60 SHREDDER
You have to remove the top cover. Look under the top and remove screws. Gently lift top and do not stress the connecting harness. carefully remove paper shreds. Unplug of course!!
Posted on Jul 22, 2009
Misfeed detected. Remove paper indicated by 0
misfeed is different then a jam. jam is the paper hit something miss feed the paper rollers can not pick up the paper. clean the rollers or replace them and or there associated clutches
Feb 21, 2014 | Konica Minolta Bizhub C451...
Printhead cartridge jams
Hello, sorry took so long but, seems to be a paper jam or loose ink cartridge, open lid with unit unplugged and try and see any paper jammed in rollers or pieces of paper, then with that done and hopefully fixed but if not, close lid and turn unit on then open lid to access print cartridges make sure they are installed right and the right ones in the right slots if the cartridge unit don't move so as to load cartridges in try to gently pull it to position as a cartridge may have not been locked in or jarred loose.good luck hope this is of some help.
Dec 09, 2011 | Kodak   ESP5250 Es Printer
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
Jul 19, 2009 | Office Equipment & Supplies
2 pieces are jammed and I can not find access to remove
Is the paper jam in the fixing unit? The Hot area before the paper comes out? If so, I believe if you are looking at the exit section to the rear of the copier there should be a same Green lever that you can move and it will release the preasure of the fixing unit. The only bad news of jams in the fixing unit is if you have any pieces of Black plastic that have came out of the copier, you may have to change the fixing film.
Mar 19, 2009 | Office Equipment & Supplies
Paper jam message
Look for little pieces of paper that get stuck in the rollers, also verify that the gears and roller didn't get misaligned when you cleared the jam.
Good Luck,
Mar 02, 2009 | Canon MX310 Office All-In-One Printer
PAPER JAM
Open your printer and check inside in all compartments where the paper goes thru. After that use some dust spray to eliminate all possible little pieces of paper.
Jan 23, 2009 | Canon SmartBase MP730 All-In-One InkJet...
Deskjet 656c series printer
I'm afraid my solution was a very untechnical one - I tore off the damaged pieces of paper that I could reach, then spent a very long time gently pulling on individual pieces of paper, which were at first jammed solid, until at last one "gave", and I was able to withdraw the other pieces.
I'm sure there must be an easier way by dismantling something, but I didn't want to do that without advice.
Apr 29, 2008 | HP DeskJet 656cvr InkJet Printer
OfficeMax 0M96431 Shredder Logo
617 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
ROCKIT957
Randy Schumann
Randy Schumann
Colin Stickland
Colin Stickland
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
