Question about Kenmore Elite HE4 Electric Dryer
My dryer starts but turns off once I take my hand off of the button
  • Kenmore Master
  • 8,220 Answers
Broken belt? Just a guess
Posted on Jul 17, 2009
Tdc30 start switch doesnt stay
It is the door switch that is the problem.
Nov 07, 2012 | Dryers
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Hotpoint dryer was moved, now only clicks, won't start
Rough handling may have the drum belt to get binded. Try turning the drum by hand to see if it turns free or is locked. This may align the belt to the motor or may just take off the belt altogether from the motor. You will have to get inside access to see whats up. Once inside realign the belt to the motor and pulley assembly. Then CHECK ALSO that no wire connections inside came apart during moving. Good luck
Jul 10, 2010 | Hotpoint NLL113EYWO Electric Dryer
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
Dryer will not start, just beeps once when start button is pressed. I hear a single click behind the control panel/head too.
HAVING SAME PROBLEM TURNED OUT TO BE THE TEMP SWITCH ON THE DRYER BLOWER DUCT,CALLED THE THERMAL FUSE .SIMPLE REPLACEMENT DRYER RUNS FINE COST AROUND 30.00 DALLORS TO FIX.
Mar 07, 2010 | Kenmore 67032 Dryer
Dryer won't start once button pushed.
most of the time this is caused by the centrifical switch you can take the dryer apart and clean the motor some times this will fix if not replace the motor try setting the timer to 60 min open the door hold down the door button and give the drum a good spin clockwise but watch your hand so the drum dont rap your nuckles
Mar 31, 2009 | Frigidaire Dryers
Dryer won't run right
The motor in your unit has to be replaced. The centrifical sw can't seem to keep the motor going. The shaft may spin freely, but once power is present the shaft locks up therefore your over amping the motor and it then trips the breaker. Since you already had the unit apart you will do fine replacing the motor. Good luck
dmparenti
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
77 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
