It will not turn on, it will just blink the button lights on and off, also it will make a beeping sound.
SOURCE: Amana portable air conditioner will not turn on.
drain the water. Same problem, it fixed it. alot of water in there Be careful
SOURCE: SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
SOURCE: model # m6p09s2a portable maytag
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
SOURCE: Blinking Nature Indicator Light
air conditioner will run fine and then shut off. When it does this the nature indicator light on the unit begins flashing If I attempt to turn it back on the fan revs up and then shuts off 15seconds later. I'm not sure what it's trying to convey with theblinking light but when the AC shuts off...
SOURCE: I purchased and LG Model# LP1010SNR on 8-3-10 at
What happens on this unit is it will suddenly stop followed by a series of chimes. You can reset the unit, but it will end with the same set of chimes. My unit display had a P2 code. As mentioned above, I drained the water (small amount actually) in the shower. Note: There is a cap towards tha bottom of the unit that you will need to unscrew, then pull out the rubber plug. Fired up the unit after the water drain ... it worked fine. If they can make a GI Joe talk ... why can this unit simply say ... "Please Drain". P2 is so intuitive.
