2010 GMC Sierra 1500 Logo
D
Deanna thornburg Posted on Jun 28, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2010 GMC Sierra radiator fan loud and seems to run all the time 5.3 vortex
It has two electric fans when it turns on you can hear it
L Pfaff
Level 3:
Top Expert:
  • GMC Master 11,573 Answers
  • Posted on Jun 28, 2016
L Pfaff
GMC Master
Level 3:
Top Expert:
Answers
11573
Questions
0
Helped
3587545
Points
181713
Deanna, check to see if your A/C is in the on position, this could cause fan to run a lot. If this is not the case, take truck in for diagnoses at a good shop, could be a faulty heat/fan sensor or sticking relay. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Diagnose Engine Cooling Fan Relay Problem
2007 Chevy Silverado Fans Always Run Engine Cooling Problem 2007
cooling fan running all the time
I own a 2005 GMC Sierra which has been consistently low on radiator coolant and fluid level for a few months. There are no apparent leaks, have had the radiator looked at, but have not solved the...
look at the oil level and color if it is choco milk color probably head gasket.is the engine noisy or fan. if fan? it is locking up because of the high heat from rad.normal. if engine possible coolant in the oil.
2answers
2005 gmc sierra radiator fan staying on
its coolent temp sensor for the radiator fan check it if not that a bad radiator fan relay.
My 1990 GMC Sierra runs hot when ac is on
Check the radiator fan to make sure it is turning at full speed. Could be a bad fan-clutch.
3helpful
My 02 Camry v6' battery was removed for 30 min and put back on - good battery. Engine starts no problem but stalls at idle. No error code. Is a computer-code reload or IAC cleaning ? Seems the car computer...
idle learn procedure:
turn off all electrical items (AC fan, audio, lights, defogger, etc.)
Start the engine and hold it at 3,000 rpm with no load (in park or Neutral) until the radiator fan comes on or the engine coolant gauge shows normal running temp.
Now let the engine idle for a minimum of 5 mins with no electrical loads. If the radiator fan cycles on during this time, you must add the fan running time to the 5 mins.
1helpful
The fans begind me radiator willnt shut off in my 2005 gmc sierra
If you read the label on the radiator shroud/fan cowls, you will see that it says "Warning--These fans may operate at any time, even if the ignition is off."
This means that the computer monitors the coolant temperature through the sensor in the water neck, block, or radiator, and turns the fans on if any of them reports (true or not) that the coolant is too hot.
Obviously, there is nothing wrong with the fans, because they run.
First, check your coolant level; if it's too low, then the engine actually boils the coolant in the radiator, causing it to flash over to steam, which is hotter than the thermostat is set to allow the engine to operate. Check this in the radiator itself, not the coolant bottle, with the engine of course cold at the time of your check.
You have, at the least, a false signal from one of these sensors.
You could also have a faulty fan relay in the distribution box under the hood on the driver's side of the vehicle.
You could also have a faulty ECM (hope it's not that one...$$$).
Please let me know if this helps you, and remember to vote/comment.
1helpful
Heater fan runs while ignitions is turned off pulled fuse but the fan can still run but only intermitly
Heater or radiator? The radiator fan is running to cool the coolant down (since the engine isn't running, no air moves through the radiator) and extend your engine life. It's what it's supposed to do. Don't worry.
Regards,
matt
1helpful
2000 gmc sierra 2500 the engine temp rises when stopped. It has a 6.0 V8 i also noticed the transmission temperature is going above 200degrees, thats never happened even hauling loads in texas heat
Just guessing but, I'd say either fan clutch is going bad, not turning as fast as it should be once temps go up or if you have electric fans, either fans or relays bad. I'm leaning more toward the fan clutch. The fins on the impeller of the waterpump can also wear done over time and reduce the amount of water flow.You may also want to make sure the fins in the radiator are clean and not stopping air flow. I'm assuming that when you're moving there's no problem so that should say that water pump, thermostat are doing good. Please rate this. Thanks
GMC Sierra A/C Stops Cooling After Driving a Few Minutes
It sounds like you either have an condensor fan problem or low freon. The condensor fan is near the radiator. In some cases the radiator fan doubles as the condensor fan. So look there too.
1helpful
3answers
1998 gmc sierra blower motor runs Intermittently
does anyone know what the problem is???? 1998 GMC Sierra blower motor problem.... when fan is turned on it works fine then all of a sudden it makes a loud screeching noise and sounds like its gonna blow up, does it on all speeds. please help
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
