SOURCE: My visual land tablet is frozen on the lock
follow this steps and fix it. GOd bless you
Press the power button. Hold it for 20 seconds to force the unit to shut down.
Remove the power adapter or USB cable from the Tablet. Turn it
back off. Turn the Tablet over and remove the screw from the back of the
device. Slide the battery panel off of the Tablet and pull the battery out
of the unit.
Connect the Tablet to the power adapter and power it on. The
freezing issue should be fixed and your Table should respond properly.
Reinsert the battery and charge it to full before removing it from
power.
Read more: http://www.ehow.com/how_8722116_troubleshoot-frozen-nook.html#ixzz2aUBnGy3w
Press up and down volume buttons at the same time and the options should show up.
Testimonial: "Still did not work. Any other suggestions? Please and Thank you for your help."
SOURCE: how much does it cost to have the screen replaced on my grandaughters 9" visual land tablet
It is normally cheaper to replace it.
If you can't take it back to your dealer, try contacting a computer science teacher at your local high school or community college and see if they can put you in touch with a student who could help you out. That would probably be the cheapest option.
Try a hard reset first:
Hard Reset Visual Land VL 109 Tablet Connect 9
defective screen display, change by an expert,professional
