Question about HP Photosmart C5180 All-In-One InkJet Printer
Error 0xc18a0106 and I've followed directions to correct the problem with no luck, changed to new ink cartridges etc
  • 4,041 Answers
Hi gave it a go I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 08, 2010
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
Error 0xc18a0106
This is most common error in inkjet HP inkjet printers.But you are not mentioned model number, any how try this:
Step 1.
> Remove all the supplies like print heads & cartridges..
> Remove USB or any other device connectivity from system.
> Switch off the printer.
> Wait couple of minutes.
> Switch on the printer, wait till printer asked for the supplies.
> Insert supplies as per specified messages.
> Check for ready mode, insert data cable & give print command.
>>>Check.. no message.. END.
Step 2:
> If problem remain same..(I will suggest for tech guys)
> switch off the machine, remove all the supplies
> Open printer side covers.
> find out the CMOS batter mounted on formatter ,remove it..
> wait couple of minutes..
> with out CMOS batter do the above said step 1 process.
> check.. I hope it will resolve this issue..give print command.. verify..once its resolved CMOS batter has to be installed.
> Switch off the machine,
> insert CMOS battery,
> do again step1 process,,..
......END....
Best of luck...Thanks for choosing FIXYA
Dec 12, 2011 | HP PhotoSmart Office Equipment & Supplies
0xc18a0106 error from hp 3310 printer.... ink system has failed
That error code indicates a Ink system failure error message. Ink system failed mainly caused by your cartridge spitting extra inks into the copper contacts inside the printer. All you need is to remove all cartridge, clean the copper contacts at the back of it, clean also the contacts inside the printer (cartridge slots). Insert it back in after cleaning, unplug the power cord without turning off the printer, wait for 1 min before plugging it back in. Let me know the result.
Nov 23, 2010 | HP Photosmart 3310 Printer
Error 0xc18a0106
That Photosmart error tells you that your ink system has failed in some way. With so little information all I can suggest is that you check to see if your ink cartridges are empty. Disconnect the USB cable, and then pull the ink cartridges out. If they're the clear type you can see the ink levels. Unplug the machine for a couple of minutes. Plug it back in, replace the cartridges and see if the error is gone. Hopefully you can now print again...
Aug 05, 2010 | Office Equipment & Supplies
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
My printer is canon IP 1900 Series. my canon problem is error messege display ''the following ink may run out.balck.. the function for detecting the remaining ink level will be disabled since the ink level...
It would appear that the black ink cartridge is either out of ink or running out soon.Change the cartridge.If your need to print now and don't have a new cartridge try this open the unit pull out the black cartridge shake it and the reinstall it you may get a little more out of it.If this is a new printer the cartridges install are always limited in use,so you'll buy more.If you must print know try changing your font color to dark blue avoiding black.Good luck.
Sep 05, 2009 | Office Equipment & Supplies
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
Mp140 e2
E3 – Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
E4 – Empty ink tank.
How to correct, fix: An ink cartridge is empty. To cancel printing, press the <Stop/Reset> button. To continue printing, press <Black> or <Color> button. After printing completes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause the machine to malfunction.
E5 – The ink cartridge(s) is not installed. The ink cartridge(s) cannot be recognized.
How to correct, fix: Make sure to install both ink cartridges even when you set the machine to use only one ink cartridge in printing. If one of the ink cartridges is missing, this error can occur.
E7 – The ink cartridge is not installed in the appropriate position.
How to correct, fix: The ink cartridge is not installed in the proper position. Install each ink cartridge in the proper position.
E8 – The ink wasteabsorber is almost full.
How to correct, fix: The waste ink absorber is getting full. Press the <Black> or <Color> button to clear the error and continue printing. Printing can continue until the waste ink absorber becomes full. If the waste ink absorber becomes full, the machine will require service. The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations.
E9 – A specified period of time has elapsed without receiving a response from the digital camera. A print mode compliant with PictBridge is not selected. A specified period of time has elapsed without receiving a response from the digital camera.
How to correct, fix: The machine cannot communicate with the connected camera. Disconnect the cable between the machine and the camera to clear the error. Check the following items, then try printing again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct. If the camera does not support either one, the machine cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge. Please refer to the camera instructions for more information about procedures required before and after connection to the machine.
3. There may have been no response from the camera for the prescribed time. Re-connect the cable between the camera and the machine.
E14 – Ink cartridge cannot be recognized.
How to correct, fix: Unsupported ink cartridge may be installed.
E15 – Install only recommended ink cartridges.
How to correct, fix: Install only recommended ink cartridges.
E16 – The ink level cannot be correctly recognized or detected.
How to correct, fix: A used ink cartridge may be installed, or the ink cartridge is empty. Press the <Black> or <Color> button, to clear the error and continue printing without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate.
E19 – Scanning failed error.
How to correct, fix: Scanning a document failed. Check if the document is placed in the correct orientation position and try the operation again.
Aug 01, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Error message
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support, if you are not getting ink system failure along with Error 0xc18a0106 then power cycle the printer and then reset, this will resolve the issue.
Jul 03, 2007 | HP Photosmart 3210 Printer
HP Photosmart C5180 All-In-One InkJet Printer Logo
345 people viewed this question
Seeker5211
Seeker5211
